ASUS VW246H backlight cuts out in 1-2 seconds
  • norcalx360repair
    • Nov 2011
    • 12
    Hi, someone brought me an ASUS 24 inch monitor(VW246H) and the backlight cuts out very quickly. Video is still ok confirmed with light. I googled this every which way and there isn't much info on this problem.
    I opened it up and this one has PSU and inverters on one board. Board number is 4h.onc02.a01. All caps and everything else looks good on it but I know this doesn't mean they aren't bad.
    I was hoping someone has seen this before. I don't work on monitors or tv's much at all and this is for a coworker so free type thing to try to help him out. Any help would be greatly appreciated.
    I found similar PSU/Inverter boards on ebay for like $22 shipped but they aren't exact model.
    Thanks!
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Re: ASUS VW246H backlight cuts out in 1-2 seconds
    I would check the caps. I have a 15" Hansol that did this exact same thing, and none of the caps were bloated, however I found a 470uF cap near the backlight inverter had failed (lost most all of it's capacitance). Replacing that brought it back.
    • norcalx360repair
      • Nov 2011
      • 12
      Thanks for reply. Unfortunately, I don't have any way to even check capacitance now. I actually found the service manual for 26 inch version and I believe they use the same board. I'll check more and report back.
      Last edited by Uranium-235; 05-29-2013, 01:01 AM. Reason: sorry, thought it was my post, didn't reload my post when I hit the back button
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        for a monitor this big, and expensive, I would replace every single cap, including the small ones (starter caps)
        edit: correction. I would try to replace every cap but the biggest one first (including the small caps). If that fails, replace the big one
        Last edited by Uranium-235; 05-29-2013, 01:02 AM. Reason: this is my post. there are many like it but this one is mine
        • norcalx360repair
          • Nov 2011
          • 12
          I'll see if I have suitable replacements and report back. I have plenty of other boards I can check. THanks.
          EDIT:No suitable replacements. I found that there is another compatible board part number. 5e-0nc02-001. Can't find it anywhere though.
          • norcalx360repair
            • Nov 2011
            • 12
            When the backlight does come on for a quick couple seconds or so the screen is bright. I've been reading and some people say this can be due to a bad backlight tube but it will seem more dim than it should be. Since it is bright it doesn't sound like that is the issue, right?
            I actually found a replacement power/inverter board but would suck if it ended up being the tube.
            • rs2klee
              • Jan 2020
              • 2
              • england
              i kinda have the same problem is to why i joined the site, same monitor powers on then flash`s the screen then goes off, but the blue power light still stays on!
              • user546087
                Keyboard backlight too bright - Asus Zenbook S16 / UM5606
                by user546087
                I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
                - kindly ask Asus for an adjustment - they basically told me to STFU and get lost It is not possible, they say. Of course.
                - tint the keycaps from behind - I have already tried that - it is kind of a last resort
                - try to find out, how it is done, look at schematics - this is, where we are at.
                - maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...
                02-24-2025, 02:03 AM
              • FallenOne008
                Asus G712L No Screen Backlight
                by FallenOne008
                Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                03-31-2025, 08:27 PM
              • obdcart
                Asus X415ea Adding a Keyboard with Backlight
                by obdcart
                Hello my friends i hope you can help me, i have just replace a keyboard with non backlight on a Asus X415 Laptop and i already install a Keyboard with backlight, the motherboard has the conector and ic's to control the light but i doens't work, i already try with a new installation of Windows and it's the same and injecting 3v/5v to the backlight flex it turns on the light, i think must be disable on Bios or need a jumper configuration.
                I hope you can give me some help
                06-28-2024, 02:21 PM
                ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
                This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                09-07-2024, 01:00 AM
              • grimacelord
                ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                by grimacelord
                I have spent the last hour on this and I guess this is just over my head, so here I am.
                I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                07-10-2025, 02:52 PM
