Help with dead Commodore 1802
    Re: Help with dead Commodore 1802
    just a thought, check the mains smoothing cap - the big electrolytic.
    I temoved it and my component tester says consistanty its around 54nf when it should be 150uf 400wv. I still have this resistor showing a dead short that isba red,purple,silver,silver
      red purple silver silver is 2.7ohms 10% i think - that's probably less than your test-leads, so it's fine
        So if that filter cap is 54nf is it ok? Its marked as 150uf and 400wv. Isn't 54nf nano farad?
          yes, it's fuckered as AVE would say!
          that could have been the fault.
            That main cap. being open would cause the problem. I had a power smps recently that had a near open main filter and it would blow the main fuse even though everything else (fet etc.) checked ok. All I needed to replace was the main filter and the power supply worked.
              Right so I just use a 150uf 400v one then?
              What is 400wv or is that just volts?
                WV= Working Voltage. Thats how they some were marked in the past. it just means Voltage rating of the cap.
                  you can use 450v if it helps it fit the board better
                  a rubicon BXW series is probably a good choice if the size matches.
                    Some older capacitors may also have two voltage markings; WV for Working Voltage, and SV for Surge Voltage.
                    -David VanHorn
                      try tweeking the focus control - if you know your cables are well shielded
                        focus can drift as components age - try ajusting it.
                          At last the replacement capacitor arrived.
                          Ive soldered it in a plugged it in and nothong happened and neither of the light bulbs we soldered in lit up. Should they have? Should i remove that bulb bridging where the resistor was and solder back in the resistor now.
                            check your fuses - the lamps should do something even if the cap was not fitted
                              There is 250v ac entering the psu and the fuse is ok.
                                refit / connect everything other than the big resistor and try.
                                  Ok done that and it powered up without blowing anything but can see anything like the power light iluminate but at least i dont think anything blew.
                                    That was a bit unclear. Ive plugged it in and its taken power without blowing anything so thats got to be good. I still have the light bulb in place instead of the big resistor but I removed the light bulb and soldered back in the coil. I can sometimes faintly hear something when i turn it on but otherwise it doesnt do anything.
                                      so the only lamp is inplace of the inrush resistor?
                                      then it should be glowing.
                                        No the lamp thats in place of the resistor doesnt glow and the heater on the tube isnt glowing either.
                                          i'll go over the schematic again on saturday
