Good day
As per title the Acer TravelMate 8573 gives a notification in windows saying "Plugged In, NOT charging"
Also the LED blinks (slowly) - In normal charge mode it should be lit solid *Orange*.
The things I tried.
Working from the BAD50-HR schematic.
Basics:
1. Tried new original battery. (3 cell) 10.8v
2. Tried new generic battery. (3 cell) 10.8v
3. Tried Original AC adapter.
4. Tried Generic AC adapter.
Advance:
1. Replaced Charging chip: BQ24707ARGRR-GP as per schematic. Though on the chip itself its shortened to: BQ07A
2. Replaced LODRV & HIDRV Mosfets, in the sense that they may have been misbehaving. (PU4005, PU4004)
3. Checked Inductor (PL4001) continuity is good, resistance was okay. Will get a definite check on this again because most tests was in circuit.
4. Resistor (PR4022) on B+ = 15Ohm
5. Replaced PQ3901, PQ3902, PQ3903 (AO4813-1-GP) These are on the Battery switcher circuit. See the images I attached.
6. Can't replace the MAX1773A Battery switcher because I don't have an extra one yet, they are on order 45-60 days... This is the last thing even though I don't think its it causing it...
Advance Continued:
So when you have the AC adapter connected everything works fine. In means it switches on and works normal. As soon as you plug in the battery BATA+ & B+ line goes 12.6V (roughly) then slowly drops down to 0V. Slowly in the sense of 0.5-1.5 seconds. When you disconnect the battery again, the voltage goes back up to 2.5 - 2.7V
Pins on BQ07A
ILIM - stays at 3.3V
IFAULT - 0V
LODRV - 0V without Battery / Battery connected = Brief moment 12.6V and goes down slowly
PHASE - 2.5V - 2.7V with Battery disconnected / Brief moment 12.6V and goes down slowly to 0V when Battery connected
Please let me know if more info are needed because I'm doing this from the top of my head at the moment... *Have other work to attend to*
Kind regards
MJ
The things I tried.
Basics:
Advance:
Advance Continued:
Pins on BQ07A
IFAULT - 0V
Kind regards
MJ
