Hello guys. I have a problem with my Samsung LED Tv UE46D6500 and hope to find a cheaper soultion with your helps.
Here is the situation. I have this tv since 2011 and never had any problem, never got repaired and even cover opened. Recently it's started to not turn on. When I plug the cord stand by led lights steady. When push to button to turn on "Smart TV" logo shows up and turns off with an endless cycle.
I opened the back cover to control the boards as general symptoms shared by people led me to check the capacitors. During the cycle the power board clicks. All capacitors are in very good physical condition, no burn or color change visible. No cracked or bad solder joints visible.
With a multimeter I checked the fuses and they're all good. To identify which board has problems I removed 22pin (to the main board) cable and cables to the led panel then did some measures. Here are the readings:
1 OD_LEVEL 5.3V Max - fluctuating
3 OD_ON/OFF 5V Max - fluctuating
5 GND Continuity checked - OK
7 B13V 12.8V Max- fluctuating
9 B13V 12.8V Max- fluctuating
11 Vamp 13V - constant
13 Vamp 13V - constant
15 GND Continuity checked - OK
17 B5V 0V
19 B5V 5.4V - constant
21 N. C 5.4V - constant
2 P_DIM4 0V
4 P_DIM3 0V
6 P_DIM2 0V
8 P_DIM1 0V
10 B13V 12.8V Max - fluctuating
12 BLU 4.8V - constant
14 GND Continuity checked - OK
16 GND Continuity checked - OK
18 A5V 0V
20 POWER 5.4V - constant
22 N. C 3.4V - constant
Fluctuations are between 0V and the max reading.
There are two high voltage (450V) capacitors and they gave me around 380V
With the results above I assume power board has problem, so any idea, experience or helps to identify where the problem is, are appreciated. I also attached the photos of the power board. Thanks
17 B5V 0V
2 P_DIM4 0V
4 P_DIM3 0V
6 P_DIM2 0V
8 P_DIM1 0V
18 A5V 0V
