I have a Sony XBR-65X850E that won't power on, and has no status lights.
Immediately upon plugging in the TV, it tries to power up (before pressing anything). I can tell because after plugging the TV in, the main transformer on the power board begins buzzing, 2 seconds on, 2 seconds off, and it does this exactly 7 times before the TV goes back to an “OFF” state. If I press the power button on the TV, the same cycle repeats. I can confirm that no ‘status' LED's are lighting up when this happens. The backlights also do not turn on, but I can confirm that they at least “light up” when power is applied to them, because I have an LED tester that I applied to each bank (at the power board connector) and could visibly see the backlights come on.
Unplugging the backlights and plugging in the TV set produces the same results. Unplugging the main board and plugging in the TV causes the TV to do nothing at all (even if the power button is pressed).
Connector CN6801 (+ LED's pinouts):
When TV is turned on:
Pin 1 +OUT1 (2BLK) = Jumps between +40V - +80V (rises to 80V when buzzing)
Pin 2 +OUT2 (1BLK) = Jumps between +40V - +80V (rises to 80V when buzzing)
Pin 3 +OUT3 (1BLK) = Jumps between +40V - +80V (rises to 80V when buzzing)
Pin 4 +OUT4 (2BLK) = Jumps between +40V - +80V (rises to 80V when buzzing)
Connector CN6802 (- LED's pinouts):
When TV is turned on (RESULTS WERE GENERALLY INCONSISTENT):
Pin 1 NC = No connection
Pin 2 NC = No connection
Pin 3 (CN6802-1) -OUT1-1 = Jumps between -60mV - +60mV (rises to +60mV when buzzing)
Pin 4 (CN6802-2) -OUT1-2 = Jumps between -60mV - +20mV (rises to +20mV when buzzing)
Pin 5 (CN6802-3) -OUT2-1 = Jumps between -60mV - +30mV (rises to +30mV when buzzing)
Pin 6 (CN6802-4) -OUT3-1 = Jumps between -60mV - +40mV (rises to +40mV when buzzing)
Pin 7 (CN6802-5) -OUT4-1 = Jumps between -75mV - +5mV (rises to +5mV when buzzing)
Pin 8 (CN6802-6) -OUT4-2 = Jumps between -80mV - +100mV (rises to +100mV when buzzing)
Connector CN6401 (Main/T-Con pinouts):
When TV is off (plugged in, not making noise):
Pin 5 (CN6401-5) STBY3.3V = +3.51V
All Pins except Pin 5 = 0V
When TV is turned on (transformer making buzzing noise):
Pin 1 (CN6401-1) BLINKING = 0V
Pin 2 (CN6401-2) PWM1_DIMMER = 0V
Pin 3 (CN6401-3) DC_DIMMER = 0V
Pin 4 (CN6401-4) PWM2_DIMMER = 0V
Pin 6 (CN6401-6) PWM3_DIMMER = 0V
Pin 7 (CN6401-7) BL_ON = 0V
Pin 8 (CN6401-8) BL_ERR = rises to +1.7V when buzzing
Pin 9 (CN6401-9) POWER_ON = rises to +3.48 when buzzing
Pin 10 (CN6401-10) GND = 0V
Pin 11 (CN6401-11) GND = 0V
Pin 12 (CN6401-12) GND = 0V
Pin 13 (CN6401-13) REG12V = rises to +10V when buzzing
Pin 14 (CN6401-14) REG12V = rises to +10V when buzzing
Pin 15 (CN6401-15) REG12V = rises to +10V when buzzing
Pin 16 (CN6401-16) REG12V = rises to +10V when buzzing
Pin 17 (CN6401-17) REG12V = rises to +10V when buzzing
Pin 18 (CN6401-18) REG12V = rises to +10V when buzzing
Pin 19 (CN6401-19) GND = Not Connected
Pin 20 (CN6401-20) GND = 0V
Pin 21 (CN6401-21) GND = 0V
Pin 22 (CN6401-22) GND = 0V
Pin 23 (CN6401-23) GND = 0V
Pin 24 (CN6401-24) GND = 0V
Pin 25 (CN6401-25) TCON_VCC12V = rises to +50mV when buzzing
Pin 26 (CN6401-26) TCON_ON = 0V
Pin 27 (CN6401-27) TCON_VCC12V = rises to +50mV when buzzing
Pin 28 (CN6401-28) TCON_VCC12V = rises to +50mV when buzzing
As a last note, I can smell burnt electronics coming from the power supply board, but there is no visual damage on either side of the power supply board (although the heatsinks are soldered in place, so I can't really see or test any of the MOSFETS). I mostly just want to rule out other boards (or the LED's, for that matter) as the problem, because every board is expensive for this TV. Is it definitive that this power board is bad?
Thanks in advance for any assistance that can be provided!
