Can anybody please help me to make "remote control light and fan switch". For 2 light and 1 fan speed contro. I need the diagram and the program and advive. My mail: masud4455@yahoo.com. Thanks.
Remote control light and fan switch
Re: Remote control light and fan switch
Info about the fan itself? You want to control it with PWM or have 9 separate terminals for the different speeds? You can use MC in both cases. Like PIC18F84A.
But not directly, you have to galvanically separate the outputs of the MC from the mains.Last edited by televizora; 04-12-2020, 11:40 PM.Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
Originally posted by televizora View PostInfo about the fan itself? You want to control it with PWM or have 9 separate terminals for the different speeds? You can use MC in both cases. Like PIC18F84A.
You just treat the MCU as if it was a "passive" internal to the device (like a run cap).
But, developing an MCU solution may be beyond the OP's capabilities/resources.
E.g., rather than design/program/build something to allow me to turn the garage lights on/off from inside my car, I just salvaged the control board off an old garage door opener and wired the relay on the board to switch power to the garage light, instead of the GDO's internal light that it was originally designed to control. I then "programmed" one of the extra buttons on the car's remote to talk to THAT opener. Press one button to open/close the door, another to turn the light on (let it self-extinguish just like it would in the original GDO)
Originally posted by Curious.George View PostIt makes much more sense to separate the (user control) inputs from the MCU and let the MCU "ride the mains" (transformerless power supply). Particularly if you intend the "controls" to be remotely located -- coupled to the MCU via an RF or Ir link. You just treat the MCU as if it was a "passive" internal to the device (like a run cap).
You always separate the control part from the commutation part if you can. This is a must.
I would use MCU, connect the output to a transistor, and would use the transistor to switch a relay.Last edited by televizora; 04-16-2020, 05:18 AM.Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
Originally posted by televizora View PostI would never ever connect MCU via transformerless power supply. The MCU-s need stable input voltage. And switched mode power adapter costs almost nothing.
A switched mode power supply HAS a cost. For loads with high variation (harder to design as "transformerless") the MCU can regulate it's own power supply (the MCU controls the "switch" that gates power to it's regulated supply). But, the load that the MCU and triac drives represent in this particular application are largely constant so no need for that capability.
http://www.seekic.com/circuit_diagra...t_diagram.html
https://www.homemade-circuits.com/si...fan-regulator/
http://www.seekic.com/circuit_diagra...er_module.html
Do you see any transformers or other isolation devices in the schematics? Relays? Do you see any "switching power supplies"? Instead, a simple zener acting as a shunt regulator and the impedance of the line coupling cap to "drop" the line voltage (220VAC) to the operating voltage of the zener (6V). Is there some reason the IC's powered by those circuits can't be microcontrollers?
http://www.hamradio.in/circuits/fan_regulator.php
"Since there is no transformer for power-line isolation, the user must be very careful and assess the risks from electric shock hazards."
There's a big difference between how hobbyists (with lots of time and little concern for RECURRING costs as they're only building "one") and industry approach design problems! (Do you really think a hobbyist would design a TV to fail after a couple of years of service??)
Originally posted by Curious.George View PostYou've obviously never designed high volume electronic equipment?
It's absolutely true that you can use ballast cap and power MCU from the line directly. But now we speak about amateur that doesn't even know what kind of fan he has. We have to be cautious in our advises not to kill someone. The chip that makes a switched mode PSU to work is fed voltage almost directly from the line - the PWM IC. The truth is that I would rather prefer to isolate from the line and work with low voltage just to be safe. And I mainly work with digital IC-s and low voltages. So this is my approach. One can do what you say, but has to be sure that noone can get in direct contact with the mains. I like double insulated equipment. In this case he has to build something that he probably would never build a second time.
Nevertheless, you cannot run a 230V fan directly from a MCU and you have to use other element to commutate the mains. PWM PSU-s use transistors connected to a IC. But if he has a fan with 9 separate terminals for the different speeds(I highly doubt it) he can just connect the MCU to a PSU, connect 9 transistors and use them to drive 9 relays. Because you cannot drive a relay directly from a MCU.
If we have a FAN that can be PWM controlled, the best approach is to power the MCU from the mains, use a transistor to commutate the mains. Or opto-isolator. I have a plenty of 9 and 12V PSU-s from routers, so it's not a big deal for me. In the first case with 9 terminals he can just use a simple 9 position rotary switch.Last edited by televizora; 04-19-2020, 11:31 AM.Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
Originally posted by televizora View PostI work with computer equipment. So my approach is to galvanically isolate as much as I can or connect to a single ground point. This way you cannot burn something via the current that can run between two points with a different ground reference via the common GND conductor.
Hard to imagine he's going to create an MCU solution -- isolated or not -- any quicker, easier or cheaper than, for example:
"If all you've got is a hammer, then everything looks like a nail" -- MCUs aren't a panacea.
Originally posted by Curious.George View Post"If all you've got is a hammer, then everything looks like a nail" -- MCUs aren't a panacea.
Also, complex things are much easier to do with MCU-s, because you can program the MCU what to do.Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
Originally posted by televizora View PostAnalog circuits often rely on a many components that have to be with precise values if you want a working circuit. Digital circuits have a fault tolerance and recovery.
Analog circuits automatically recover (unless catastrophic failure). MCUs resort to hacks like watchdogs and brownout detection to prevent them from PERMANENTLY locking up.
If you design anything safety-critical, you don't rely on an MCU/MPU/CPU to enforce your safety but, rather, an ANALOG CIRCUIT that is simpler and far more robust than a microcontroller and umpteen lines of code.
I'm an EE. I've been designing products with microprocessors (before microcontrollers came on the scene) for over 40 years (can you spell i4004?). I'm well aware of their capabilities AND limitations. The "hammer-nail" analogy is a good one for folks who see every problem as needing an MCU-solution. (it likewise applies to folks who think they can come up with an analog circuit to address every problem)
[As a kid, I used to repair pinball machines, "part time". I recall meeting an older technician, one day. He looked at my VOM and asked what it was. I told him what it was, what it could do, how I was using it to troubleshoot the machines, etc. He pulled a length of wire out of his pocket that was obviously old -- the insulation cracked, wire frayed, etc. And, proceeded to show me (in a "fatherly way") how he could do everything that I claimed my meter could do with just that bit of wire. Because he knew the ESSENCE of those actions and could do away with all the fluff that my meter brought to the party!]
Analog circuits can typically be inspected IN THEIR ENTIRETY just by looking at a one or two page schematic. One can write a piece of code that you will likely NEVER understand, completely -- and you'd be hard-pressed to know if that was due to its inherent complexity (i.e., it NEEDS to be this complicated) OR incompetence (i.e., this guy didn't know what he was doing!). That's why you see so many latent bugs in even simple pieces of software -- because the developer couldn't see the forest that he was standing IN!
Witness how easily folks repair/patch SOMEONE ELSE'S hardware designs vs. how clueless they are at "patching" foreign code.
Originally posted by Curious.George View PostHow often do you see "one percent" tolerances specified for analog components? Caps are often +-20% or more -- and often used for timing-related roles. 5% for R's. Wanna guess what you see for L's? I.e., analog circuits are inherently imprecise AND STILL WORK.
I'm an EE.
I offered a MCU, because it's much easier for me to program MCU, that relies on little periphery than to design an analog circuit that is specific to the task, and If I don't like it's imprecise behavior to scrap it and start all over again.
It's much more difficult to predict the behavior of a analog circuit in different conditions. For example, if you rely on a resonant circuit, built with capacitors and etc, it would be much more flawed than if you use MCU with it's internal clock generator. And yet, I agree that if you don't need something precise, sometimes it's much easier to accomplish simple tasks with analog circuits.
P.s Im a CELast edited by televizora; 04-24-2020, 01:37 AM.Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
Originally posted by televizora View PostThese days, analog circuits are used only to do simple tasks. Everything else is digital.
Until recently, most home thermostats ("temperature controllers") were MECHANICAL systems (bimetallic strip and mercury switch).
Voltage regulators in cars used to be "tuned relays".
This is because many circuits can interact between themselves and with standard levels and interfaces this is a trivial job.
How often have you worked on a "digital" system with more than one logic family? I worked on a box that used HiNil (google it), MECL3, 10K, CMOS and TTL. Because each has specific attributes that were apporpriate in THEIR portion of the system. And the "interface" to the UUT was very sophisticated ANALOG modules (so the voltage levels and transition times could be programmed).
In manufacturing, many companies rely on PLC-s to control critical processes.
What I am trying to say is that it's extremely difficult to do complex tasks with analog circuits.
[Note, none of this requires a microcontroller]
Unless you just want to copy a design -- in which case, I've already offered completed designs!
In addition to weeding out any INDIVIDUAL tablets that are out of tolerance, you want to tweek the process as it is running (if you shut it down, you will end up discarding several hundred tablets each time it's stopped and then restarted; so, you make the adjustments WHILE its running).
Historically, this was done with a simple ANALOG PID controller that could be implemented in a large pack of cigarettes (neglecting the knobs and indicators). The entire circuit could be spread out on a table and examined, in detail, to verify that it behaved as expected. (tablets that are used for pharmaceutical purposes must be produced in "regulated" conditions to ensure the safety of the product produced)
When this was "computerized", it became "wonderful and complex". Suddenly, the simple indicators weren't sufficient -- you "needed" a graphic display. And, the simple controls were similarly inadequate -- now a keyboard is "essential" to operate it! And, man-years of labor to design and program.
Plus, the persistent uncertainty that there might be bugs in the code! (gasp!)
A box that was previously small, inexpensive, reliable and readily "validated" suddenly became large (monitor, keyboard, computer), expensive, finicky and an exercise in trust ("HOPE it's working properly!")
The "Feeping Creaturism" that is virtually inevitable with programmed devices!
My current design uses a multitude of processors "distributed" to address the specific needs of the application. I synchronize the local timebases in them -- over the network -- to better than 50ns using sophisticated control algorithms. In those cases where I know the processors to be located in close proximity, I "run a SYNC wire" between them -- the "analog" solution. Despite having the same code running on those processors as is used to synchronize them with the remaining "remote" processors. Which task is "simpler"? Which achieves better performance and less uncertainty?
P.s Im a CE
Because not all problems are "nails".
The trick is then to educate those who must "maintain" my work so they understand why particular implementation decisions were made -- instead of assuming it was just the "easiest thing for me".
I argue with you just for the sake if the argument. Meanwhile we learn things.
I prefer MCU because I don't need application specific circuit. I don't need to invent logic, just to write what I want the MCU to do. For everything else you are absolutely right. And yes, I would be idiot not to rely on WDT. And you are right, everything in it's nature is analog. Digital is just fixed set of levels. What makes digital superior in some areas is that digital is more noise resistant and precise, unless we need, the unprecise and Wideband. I also use many types of analog circuits to complement the digital. Simple things I like to do analog. PWM on the other hand with user input is not much simpler to design with analog discrete components. This is why PSU-s have dedicated PWM IC-s. It's much more reliable to limit the number of parts to it's minimum, unless this means much higher priceLast edited by televizora; 04-25-2020, 01:54 PM.Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
Originally posted by televizora View PostI argue with you just for the sake if the argument. Meanwhile we learn things.
With VHDL/Verilog, I now find it easy to design custom hardware without having to "invent logic". E.g., I had to prototype a circuit last week and it was easier to just write some VHDL and "burn" an FPGA than it would have been to wire-up a bunch of chips to do the same thing. But, I won't use an FPGA design in production simply because the "bunch of chips" approach is cheaper (and, more maintainable "after-the-sale")
Yep, nevel dealt seriously with VHDL. Not because I don't wish, but because it's not so big country with fewer opportunities for building custom hardware. So my approach is if I can't build custom IC, the closest thing I can do is to use MCUs readily available as jack of all trades. And this is preferable than building a circuit with many discrete elements, which makes it more prone ti failure.
Software solutions and MCus allow me to handle many variables with fewer hardware, make decisions, handle exceptions and update features without the need of complete rework.
And yes, some low tech solutions are better sometimes. If I need to turn on a fan, I would use thermistor and transistor(and relay if its 230v), not MCU. But if I need to handle different conditions, it's simpler to use MCU. Software one can update easily than hardware.Last edited by televizora; 04-26-2020, 01:00 AM.Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
Originally posted by televizora View PostYep, nevel dealt seriously with VHDL. Not because I don't wish, but because it's not so big country with fewer opportunities for building custom hardware.
For example, I designed a graphics processor many years ago that included an instruction that would "draw" (write into memory) the next "dot" on a line. So, if a line was 100 dots long (regardless of "angle"/slope on the screen), it took 100 instructions to completely draw it into memory. (this is probably 10-20 times faster than it would have been, otherwise, with a "conventional", off-the-shelf processor!) At the time, I had to create the logic to do that using MSI TTL components. Nowadays, I would just write some VHDL and let the VHDL compiler figure out how to program a particular FPGA to perform that identical function.
I could put much of the processor IN the FPGA!
There are commercial offerings that pair an MCU with an FPGA so you can let the MCU do the boring stuff and have the FPGA deal with any "special operations" or "special I/O" (e.g., build a PWM controller in the FPGA)
Then, some Marketing twit comes along and says the company can make a gajillion dollars by offering some new "simple" feature. That, usually, doesn't FIT in the original implementation you came up with! Now, you have to explain why you have to start over instead of just making some "simple" changes to the existing product.
"We decided we could sell a lot more of these Quonset huts as starter homes if they bedrooms on a SECOND FLOOR..."
