Non safety approved input filtering seems to be becoming a lot more common. I have a KME power supply (Branded Pixxo) that has 3 Y caps, and 3 X caps. One of the X caps is directly connected to the AC receptacle, and this one has all the normal safety approved logos and what-not. The other 2 X caps and 3 Y caps are after the fuse and do not have the approved logos. Even the X caps just say "470K 200V" in huge letters and nothing else. Do these still do the normal "duty" as safety approved X caps? The Y caps look like ceramic caps with a blue sleeve, these serve no purpose? If they were to fail would they just blow the fuse?
"Unapproved" input filtering
Re: "Unapproved" input filtering
Thanks, I'll look for some replacements. A few more questions. How come some Y caps have a ferrite bead on one of the legs? (Usually the one that is grounded) And sometimes there's a Y cap (or fake one) next to the bulk capacitors connected to the ground of the corner of the PCB, does this Y cap have to always match the other 2 (or 4) before it?
The resistor is there to discharge it when power is disconnected. There really only needs to be a resistor for one of them, as the others are connected in parallel with it and will discharge through it too. If there is no resistor at all, though, then it's a corner cut.Last edited by c_hegge; 08-07-2014, 07:11 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
Originally posted by Pentium4 View Post...the X caps just say "470K 200V" in huge letters and nothing else.The Y caps look like ceramic caps with a blue sleeve, these serve no purpose? If they were to fail would they just blow the fuse?
Originally posted by Pentium4 View Post...How come some Y caps have a ferrite bead on one of the legs? (Usually the one that is grounded) And sometimes there's a Y cap (or fake one) next to the bulk capacitors connected to the ground of the corner of the PCB, does this Y cap have to always match the other 2 (or 4) before it?
Originally posted by Pentium4 View Post...Even most cheapo units have at least one...
Those sure do their duty but in an undesired way, failure mode of ceramic caps tends to be short-circuit ITOH failure modes for X and Y capacitors are open-circuit mode (or high impedance), Y caps should have low leakeage current because they are used in line to ground applications, also X and Y rated caps are designed to withstand high voltage pulses (for a limited time) without going into failure mode, something that non safety approved caps can't do. I've attached some files about safety ratings caps and about EMI filters, hope it helps you as much as they helped me.
The ferrite bead (or ring) is there just to avoid high frequencies or so I believe, because that is what a ferrite bead do when there's no winding, it acts as a very small inductor so it can only block high frequencies. I have noted that there is some sort of correlation with the use of those ferrite beads when there's a jumper between traces to the location of the component or the component has long legs, so maybe this has to do something with avoiding the pickup of RF by the jumper or leg (that is acting like an antenna) and nothing more than that, but I maybe totally wrong.
As SIDMX mentioned, the difference between safety-rated X/Y caps and regular caps is their failure mode. Safety Y caps usually fail open, not short like normal ceramic capacitors do. With X caps, I think it is something similar, though I am not exactly sure.
If these non-safety caps not sitting behind a fuse, and they do fail shorted, you can get a hard short between Live and Ground (via non-safety Y caps) or Live and Neutral (via non-safety X caps). If you have a bad braker or bad house wiring, that makes things quite risky (but luckily, most cheapo PSUs also have very thin input wires so they may burn before the house wiring goes, if the breaker doesn't trip).
That said, even if the non-safety caps are sitting behind a fuse, you still have the risk of a live case or partially live case if grounding on the PSU is not good. As SIDMX mentioned, safety Y caps have low leackage, so touching said energized case is not as dangerous.
As far as functionality, there isn't much difference between the regular and safety X/Y caps. Both will supress RFI and EMI equally well.
Originally posted by momaka View Post...Safety Y caps usually fail open, not short like normal ceramic capacitors do. With X caps, I think it is something similar, though I am not exactly sure.
Also we need to be careful about what types are used in PSUs (or used for repairs) specially the ones before the fuse and if using a non self-healing one better to put it after the fuse don't you think?Last edited by SIDMX; 08-12-2014, 12:35 AM.
Very interesting post, SIDMX... but now I am more confused .
I always thought metalized poly caps (i.e. X caps) are bigger than their regular film cousins for a given capacitance. Yet, the article by WIMA states the opposite? Or am I way off here?
From what I understand from the text excerpt from the 3rd picture, when a metalized poly cap encounters a high voltage spike, the energy from the arc can take out the metal coating that connects the affected layers, thus removing the short. The result is loss of capacity, but the capacitor "heals itself". So if that is true, then I guess a badly abused metalized poly cap eventually looses so much capacitance that it is as good an an open circuit. Does that sound right?
In any case, I don't like when I see X caps before the fuse. If the board has a spot or more than enough X caps, I do consider removing any "excess" X caps from the receptacle (actually, I did do that on two PSUs of mine). The nice thing about that is, I have extra caps to put in other PSUs that might need them .
Okay here are some pictures of the new input filtering and an "overall" look of the PSU. Looks decent. Replaced the 20A ultra fast on the 12V with a 30A ultra fast, and replaced all the caps. I love power supplies
To be honest I'm not 100% sure either because I couldn't find a contundent argument to this, going by the citation of IEC 384-14 (first pic) that is commonly found in X2 datasheets I do believe that there is no restriction for a short circuit failure mode even if Wikipedia says the opposite, if there are not restrictions why some PSU manufacturers put X2 caps before the fuse
Originally posted by momaka View PostI always thought metalized poly caps (i.e. X caps) are bigger than their regular film cousins for a given capacitance. Yet, the article by WIMA states the opposite? Or am I way off here?
Originally posted by momaka View PostFrom what I understand from the text excerpt from the 3rd picture, when a metalized poly cap encounters a high voltage spike, the energy from the arc can take out the metal coating that connects the affected layers, thus removing the short. The result is loss of capacity, but the capacitor "heals itself". So if that is true, then I guess a badly abused metalized poly cap eventually looses so much capacitance that it is as good an an open circuit. Does that sound right?
Originally posted by Pentium4 View PostOkay here are some pictures of the new input filtering and an "overall" look of the PSU. Looks decent. Replaced the 20A ultra fast on the 12V with a 30A ultra fast, and replaced all the caps. I love power suppliesLast edited by SIDMX; 08-13-2014, 12:33 AM.
http://www.capacitorguide.com/filter-capacitor/
http://www.tecategroup.com/capacitor...capacitors.phpLast edited by budm; 08-13-2014, 11:48 AM.Never stop learning
Originally posted by SIDMX View PostNice job on that Pixxo/KME! ...there's a way to put another cap for +12V rail before the pi coil in these KME units
Originally posted by Pentium4 View PostNice! How'd you get that thing in there? Yours looks to have a bigger core transformer.
About the size of core, I'm not so sure, I don't trust KME stickers but it is posible.Last edited by SIDMX; 08-13-2014, 05:44 PM.
SWEET! Thanks SIDMX for sharing, that's awesome I'll have to do that to mine as well. BTW, nice custom RS cap
I'm going to post this in power supply build quality pictoral but figured I'd post it here too, another classic example of "unapproved" or no input filtering turned into a useful filter (there is a 560kΩ resistor under the small X cap). Scrapped input parts from the following dead PSU's: Bestec, CWT ISO, Allied, Antec SP500. I also added a bridge rectifier heatsink from a dead piece of trash Leadman
BEFORE:
AFTER:
Looks like you had fun- I like this!
Beware of the possibility of instabilities if you shift the dominant pole around. Depending on the margins in that supply's compensation, you might not be able to get away with putting a cap before that PI-choke.
I did the same in a supply I upgraded without any trouble. It, too, was a half-bridge, 5V-based design, so less emphasis on the +12 regulation may work in your favor.
Hope you can find something here that helps:
https://www.badcaps.net/forum/showthread.php?t=14405
Edit- Looks like I added the cap after a PI choke...Last edited by kaboom; 08-14-2014, 12:31 AM."pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
Originally posted by Pentium4 View PostSWEET! Thanks SIDMX for sharing, that's awesome I'll have to do that to mine as well. BTW, nice custom RS cap
