Surface 3 Clean Bios? (noob)
    Re: Surface 3 Clean Bios? (noob)
    Heya!
    1) Could someone help me out with this?
    0993C32670BA2D4DA3E04D741107BE9A5C2EC6C18C5436E8FD7B890E21A2D53579C9525CF5EF2B83
    2) I couldn't exactly understand how the XORing part was perfomed in this example: https://gist.github.com/en4rab/55088...f3039e3c8ab6fd.
    The author XORed the 1st hexstring by an other, and resulted the final useful output. Where did he got the 2nd hexstring from?
    Thanks in advance!
      @candidosobrinho.sa
      password is cAse-SeNsiTivE and it's 20-characters.
      password = RuaAdolfoHerbster447
        Originally posted by AAAC View Post
        @candidosobrinho.sa
        Thanks for letting me in! It's my street address and house number written in a way I would never guess.
        AAAC, how was the 2nd hexstring obtained anyway? Could you point me to two or three reading materials? I'm very intrigued about it.
        Best regards!
          Best regards!
          PS: I finally understood! I wasn't certain on what the 'xor-key' actually was, so explaining for others who might search for help here:
          1. I dumped this according to instructions:
          2. And Ran against this key from GitHub on this XOR calculator ~http://xor.pw~:
          5b93b62611ba6c4dc7e022747d07d89a332e8ec1e95444e89f7bfa0e55a2b0350bc9665cc1ef1c83
          3. Resulting in a ASCII 'hexchar'+00h:
          520075006100410064006f006c0066006f0048006500720062007300740065007200340034003700
          R<NULL>u<NULL>a<NULL>A<NULL>d....
          (the password!)
            Hi I received a Surface 3 from a friend and I wanted to dual boot it with Android but the UEFI BIOS settings where password protected. He gave me all the passwords he would have used to no avail. I was hoping you could do what you do so well and help me with the password, if it helps he says he may have used @ instead of the letter "a", like Retin@ or Dint@d@ly. I included the bin file I got from using the TXE2 programming tool. Thanks.
              @Pumpguy
              Try this (decoded from UEFI Variable):
              password = ADMINISTRATOR
                Thank you AAAC, you guys are the best. I tried every basic word except that one. I thought it was to simple. Thanks again.
                  Well, the last phone I found had a passcode of 0000, so you must always check all the simple passwords before asking for help.
                  A working TV? How boring!
                    Hello there,
                    I hope they are fine
                    Could you help me with my surface 3?
                    I bought one recently and suddenly it was restored and it does not come out of there, it does not advance and it is constantly restarting
                    and ho surprise the bios has a password.
                    How can I save the bin file to decrypt the pass?
                    Thanks in advance
                      Have you tried reading this topic?
                        Thanks for answering
                        Yeah sure, but if I'm on a different topic, sorry
                        I just need help
                          I just need help
                          Become a Badcaps supporter
                          Thanks to all supporters.
                            Can someone help me?
                            Please
                              What did you try after reading this topic? Where are you stuck?
                                Sorry for my English
                                I don't speak it well
                                That's why I use the translator
                                The Surface worked fine, but it restarted to do an update and it works on it, it just turns on and restarts
                                Try loading software with usb stick
                                But when wanting to change the order of the bios it is with password
                                  Google Translate sometimes "comes up" with funny sentences like your previous one.
                                  RethoricalCheese wanted to say the following - read the topic from the beginning, and you'll find out the steps you need to follow to find out what the password is.
                                    I already read the whole topic, but I can't find how
                                    I can't access windows to generate the file or boot from usb
                                      Hi there,
                                      could you please help me in decrypting the password from this dump file?
                                      I tried, and got Valentin1 but unfortunately it does not work. My surface says it is incorrect.
                                      Thanks in advance!
                                        @zdarai
                                        I do get the same password.
                                        The password is case-sensitive, are you typing the first character as an UPPERCASE "V"? Last character is Number One "1".
                                        password = Valentin1
                                        V - VICTOR ( UPPERCASE )
                                        a - alfa ( lowercase )
                                        l - lima ( lowercase )
                                        e - echo ( lowercase )
                                        n - november ( lowercase )
                                        t - tango ( lowercase )
                                        i - india ( lowercase )
                                        1 - 1 ( digit )
                                          @AAAC
                                          Thanks for your reply. This is bad news. It is not accepted by the machine for some reason.
                                          Yes, I was typing it this way... Any idea what (else) can be wrong here? Anyone here with similar difficulities? I am a little bit confused now and don't know how to solve this issue...
