Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 08-09-2021, 06:17 AM   #1
ioanban
City & State: Worthing
My Country: uk
I'm a: Knowledge Seeker
Default JVC LT-40C860 stuck on logo
Hi guys,
I have a JVC LT-40C860 stuck on logo.
I have tried all sorts of resets but nothing seems to help.
I have checked the fuses on the main board and power supply and capacitors everything seems ok.
From what i was reading on the forum I tend to believe it's a firmware problem.
Now the question, is anyone who can give me the firmware so that i can put it on a usb drive and see if it solves my problem ?
Tried contacting JVC but i got no reply.
I've attached some pictures with the boards in case anyone wants any extra info.
Thank you,
ioanban is offline   Reply With Quote
Old 08-09-2021, 07:39 AM   #2
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Default Re: JVC LT-40C860 stuck on logo
Is U13 an MX25L512 EEPROM or equivalent. If so I would freeze it with freezer spray and make cerain it gets really cold (set powered off) and then attempt to reboot the TV. You may have a failing EEPROM
__________________
dick_barton is offline   Reply With Quote
Old 08-09-2021, 08:44 AM   #3
ioanban
My Country: uk
Quote:
It is KH25L1606E. I'm just going to buy a spray and I'll give it a go
Old 08-09-2021, 09:45 AM   #4
ioanban
My Country: uk
I have frozen the EEPROM and it went over the logo but got reseted in a few seconds.
Old 08-09-2021, 09:54 AM   #5
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
if you cant find a firmware dump this maybe be your board maybe worth sending the seller a lower price offer
https://www.ebay.co.uk/itm/234098833...EAAOSwpL5g-Jxy
vinceroger69 is offline   Reply With Quote
Old 08-09-2021, 11:31 AM   #6
dick_barton
My Country: Wales
Try freezing it again and allow the EEPROM to get really cold. Give it several good blasts. Very often the inside of the IC hasn't become cold enough.
Old 08-09-2021, 02:39 PM   #7
ioanban
My Country: uk
I'll try gain, thank you
Old 08-10-2021, 04:08 AM   #8
angelos
City & State: Free State
My Country: South Africa
Line Voltage: 220V AC
I'm a: Professional Tech
I saved a tv like that. I desoldered the chip off the board and fit it in my eprom reader. Then i sprayed it ice cold and started the read process. During the read i sprayed it again. I got a data image. Saved it, and dumped it into a new blank chip and viola. It worked , tv went out back to customer, fixed.
angelos is offline   Reply With Quote
Old 08-12-2021, 05:50 AM   #9
ioanban
My Country: uk
Unfortunately the freezing didn't work for me and i don't think it's worth me buying a eeprom reader. I was looking for a firmware to use with an USB drive but no one seems to have one . I'm thinking on getting another main board.
Old 08-12-2021, 06:16 AM   #10
arizanotlari
City & State: Diyarbakir
My Country: Turkiye
Line Voltage: 220VAC 50Hz
try this : https://yadi.sk/d/_zlpfQXu5tD28w
__________________
Genç Elektronik ve Bilgisayar
arizanotlari is offline   Reply With Quote
Old 08-12-2021, 06:33 AM   #11
dick_barton
My Country: Wales
The EEPROM reader/writer is dead cheap and worth having in your tool box.
Old 08-13-2021, 06:44 AM   #12
ioanban
My Country: uk
Quote:
Originally Posted by arizanotlari View Post
I have tried with this file but nothing happens, doesn't start updating
Old 08-13-2021, 06:45 AM   #13
ioanban
My Country: uk
I have just ordered an EEPROM reader/writer . Thank you
Old 08-20-2021, 03:45 AM   #14
ioanban
My Country: uk
Quote:
Hi guys,
I have ordered an eeprom reader/writer but i couldnt get a working driver to be able to access the info on the eeprom so I bought a replacement main board and got it in. Tv is working perfect now.
If any of you has a reliable software for win10 that i can use with the eeprom reader/writer please share'it with me !
Regards,
Old 08-20-2021, 04:17 AM   #15
dick_barton
My Country: Wales
Which EEPROM reader/writer did you buy?
If it was the CH341A then here are a few progs that should work.
File Type: zip AsProgrammer_V2.1.0.13_XiTongZhiJia.zip (1.98 MB, 16 views)
Old 08-20-2021, 04:55 AM   #16
lotas
City & State: Sochi
My Country: russia
Here is another program for CH341A.
lotas is offline   Reply With Quote
Old 08-26-2021, 07:45 AM   #17
ioanban
My Country: uk
I bought the CH341A.
I'll try the progs you've given me.
Thank you
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
