Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 08-12-2021, 11:20 PM   #1
MrCreosote
Default HiSense 55HtB power supply bench test: weird voltages
There was a power surge at home from "direct" (no sound delay !!!) lightning strike. Popped a 15 amp breaker for ceiling lights (old knob and tube wiring - perfect antenna?) "Fried" garage door opener buttons and remote, KVM switch, Magic Jack, and a ceiling fan motor.
And my 55" 6 year old Hisense Black Friday Walmart TV.
There is no Red standby LED.
I was wondering how to "jumper" the board on to test voltages thinking the STB pin would be one of the pins.
However, I decided to measure voltages at all 10 pins just so see there was something there to power the standby switch. What I found was something I cannot explain: Voltages with no power connection to board. Now I was working under 4 compact fluorescent light bulbs but that is a reach.
Maybe this is telling me the board is fried?
I have the board pinouts and the voltages are (line cord unplugged) / (line cord plugged to outlet) which is beyond my pay grade. Tried 2 different multi meters.
1 gnd
2 gnd
3 pwm -0.2v / -2v
4 sw
5 12v
6 12v
7 stb
8 gnd
9 18v 22v / 24v
10 18v 22v / 24v
MrCreosote is offline   Reply With Quote
Old 08-13-2021, 09:07 AM   #2
MrCreosote
Default Re: HiSense 55HtB power supply bench test: weird voltages
OK found the following definition of the unrecognized pinouts. Also appears this board does not have a 5v standby. Here is a copy from another thread:
Where is the 5V pin on this board? I do not see one.
http://www.badcaps.net/forum/attachm...3&d=1472170236
STB = PS-ON
SW = BL-ON
PWM = PWM dimming
RE: Measured Voltages: the 24v is troublesome: much higher than the 18v spec'd.
Also, the voltage measured with no power to board could be caps still charged up? But I repeated measurements w/ and w/o power and the values alternated between 22 and 24. If charged caps, I would expect 24 and 24 or the 22 would would change with time while discharging. Could get a VOM to put a little load on it.
Old 08-13-2021, 10:58 AM   #3
lotas
City & State: Sochi
My Country: russia
I'm a: Knowledge Seeker
STB is the standby power supply (voltage DC5V).
STB can be 3 - 6v DC
lotas is offline   Reply With Quote
Old 08-13-2021, 11:06 AM   #4
lotas
City & State: Sochi
My Country: russia
PWM - backlight level
SW - switching on the main power supply 12V and 24v.
no load and will jump power to 24v.
Old 08-23-2021, 12:49 PM   #5
MrCreosote
Both STB and SW are 0v.
So I've go NO standby power supply and the 18v pins are running 24v.
RIP power supply board.
Old 08-23-2021, 12:55 PM   #6
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
I'm a: Professional Tech
I would not worry about 18V being 24V for now. The standby section should be fixable, it should be nothing more than replacing the switching IC, startup resistor and associated capacitors and maybe the optoisolator.
__________________
Quote:
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 08-23-2021, 05:05 PM   #7
R_J
City & State: ☻
My Country: Canada
I answered this in your other thread, The power supply board is working fine, it does NOT supply a separate standby 5 volts
STB is an input which requires a high (+3~5v) to fully turn on the main power supply and pfc circuit. SW pin also requires a high signal to turn on the 12V_VCC for the backlight circuit
R_J is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
