Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 05-11-2022, 12:33 PM   #1
Xristakis795
City & State: Athens
My Country: Greece
I'm a: Knowledge Seeker
Default question for equivalent igbt
hi to all
i have igbt fgd3245g2-085 can anyone to suggest me an equivalent ?because its difficult to find it and take it soon
thanks in advance
Xristakis795 is offline   Reply With Quote
Old 05-11-2022, 05:59 PM   #2
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Default Re: question for equivalent igbt
You can find them here
https://www.mouser.com/ProductDetail...fuRgBh9g%3D%3D
Just select the country from where you live and see if they have them in stock
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 05-12-2022, 10:11 AM   #3
Xristakis795
My Country: Greece
thanks a lot sir Sam just i want to buy from
https://www.tme.eu/en/details/fgd324...istors/onsemi/
in yours address the case is to252
in mine is Dpac
will i have problem in your opinion ?
and the pins of fgb3245 are same with the pins of fgd3245 right ?
Old 05-13-2022, 12:39 AM   #4
sam_sam_sam
My Country: USA
You will have to check the data sheets for both of them or you will have to make a circuit board if the pin outs are different if all other specks are the same it should work
If the website page that you posted is the exact same part number then I would order from them if you trust the company
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
