Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 10-31-2021, 07:18 AM   #1
Alexbp
City & State: Siegburg
My Country: Germany
Default I need a charger schematic YLT6722000
I need a schematic of the charger
model: YLT6722000
input: AC100-240V~ 50/60Hz
output: DC67.2V 2.0A
Alexbp is offline   Reply With Quote
Old 10-31-2021, 10:21 AM   #2
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Default Re: I need a charger schematic YLT6722000
Please post some pictures of this battery charger board front and back of the board we might be able to help you with it
Please decried what is the issue with and what you have done so far
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 10-31-2021, 03:27 PM   #3
Alexbp
My Country: Germany
top and bottom view
Old 10-31-2021, 05:16 PM   #4
diif
City & State: Midlands
My Country: England
What's up with it ?
diif is online now   Reply With Quote
Old 11-01-2021, 01:48 AM   #5
Alexbp
My Country: Germany
D3 diode was short-circuited and on U3 the supply resistance is 109 ohms
LED was always green
Old 11-01-2021, 03:54 AM   #6
Alexbp
My Country: Germany
I have a question, can I replace D3 FR207 with 1N5407?
Old 11-01-2021, 10:05 AM   #7
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
No, unless if you want to replace the 1N5407 again.
eccerr0r is online now   Reply With Quote
Old 11-01-2021, 12:23 PM   #8
Alexbp
My Country: Germany
Thank you very much
Old 11-04-2021, 10:01 AM   #9
Alexbp
My Country: Germany
replaced the diode fr207 and u3 LM358, the battery charges after 5 minutes of shorting the diode and LM358.
exactly as it was
Old 11-04-2021, 10:43 AM   #10
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
need to figure out why it's over current, surprised lm358s fry as their outputs were specced to be shorted to a rail indefinitely, but not beyond a rail.
What capacitor was there?
This can't be the 2A output, must be a feedback output of some sort...
Old 11-04-2021, 10:43 AM   #11
Alexbp
My Country: Germany
current consumption when charging 2.10A
Old 11-04-2021, 10:48 AM   #12
Alexbp
My Country: Germany
capacitor 100 µF 35v
Old 11-04-2021, 10:54 AM   #13
Alexbp
My Country: Germany
LM358 ok replaced the diode all works, but how long
Old 11-04-2021, 12:31 PM   #14
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Anything other than the diode cooking?
Putting a 1N4007 or 1N5407 or a fake FR207 will cause it to self cook.
Old 11-04-2021, 01:08 PM   #15
Alexbp
My Country: Germany
also heats up MUR1060FCT
Old 11-04-2021, 03:03 PM   #16
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Does it heat up with nothing connected?
Sure the battery that's being charged is okay?
Might be normal too, or simply underdesigned...
Old 11-05-2021, 08:18 AM   #17
Alexbp
My Country: Germany
without load all cold voltage at the output 67.4v, when you connect the battery is strongly heated FR207, the output is 54v
Old 11-05-2021, 08:22 AM   #18
Alexbp
My Country: Germany
Before it happened, the battery was connected to the bike and had not been moved for 2 months.
Old 11-05-2021, 08:32 AM   #19
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
how many volts is the battery by itself? Does the battery have shorted cells? Li-ion or SLA battery?
FR207 heating up is still kind of strange, the MUR1060FCT I can understand heating up...
Old 11-05-2021, 08:38 AM   #20
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
BTW If you must "upgrade" the FR207, you can try the FR307 but I don't think that's the right course of action...
oops accidental double post...
Badcaps.net Technical Forums © 2003 - 2022
