Thread Tools | Display Modes |
#1 |
City & State: Dublin
My Country: Ireland
I'm a: Knowledge Seeker
![]() Im hoping after all the work I put into this I can salvage something. I bought a 65 Sony tv that was flashing three red lights. I opened it and tested the leds and it one strip had failed so I went and preferred them online.
They arrived today and again I stripped the tv down and replaced the leds, but in the process I tore one of the little ribbon cables coming from then iron of the LCD ( See attached pic). I tried to tape it back down and out the tv back together and the original issue has now gone and the tv boots up but only one half of the screen is displaying correctly. The right side has lines. Can this be repaired or is there something I can do? For my first tv repair it went pretty good considering I was replacing 16 strips of leds. Thanks in advance. |
#2 |
City & State: Coral Springs, FL
My Country: USA
Line Voltage: 120V AC @ 60Hz
![]() It's scrap. Salvage all the boards and the strips and try to recoup your money.
You've got to be careful with these things. |
#3 |
City & State: Guelph
My Country: Canada
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
#4 |
My Country: Ireland
![]() Ahh no way! I thought if the cable pins made contact with the pads then it could be ok.
Cheers guys |
#5 |
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
![]() If it's scrap then I have often wondered if a domestic iron set to the correct temperature and a microscope to ensure the tracks are lined up would work. There is some information on line I have come across that give details of the bonding and temperature. Maybe worth a search.
Edit Thinking about it further if the tracks on the thin panel ribbon have come away then it would never work.
__________________
Willing to help but I'm no expert. Last edited by dick_barton; 05-23-2021 at 05:24 AM.. |
#6 | |
My Country: Ireland
![]() Quote:
#7 |
My Country: USA
![]() I've tried the iron method to attempt to get the ribbon reattached and I failed every time. My ribbons were only partially detached - I never had one fully detached like yours. Do not apply solder to these ribbons. They are attached by a conductive layer of adhesive. My guess is that they are ultrasonically bonded. Also, the tab has to perfectly aligned to the glass. None of these requirements bode well for a home repair.
Give it a try... Who knows - you may be the first to successfully reattach one of the tabs to a panel. It would give the rest of us hope for future repairs. |
#8 |
My Country: Wales
![]() An idea of tab bonding is given here.
https://www.youtube.com/watch?v=FZCAMsi2Pls |
#9 |
City & State: Midlands
My Country: England
I'm a: Professional Tech
![]() The tabs are adhered with special expensive electrically conductive tape, heat and pressure are used to apply it.
#10 |
My Country: Wales
![]() Anisotropic Conductive Film (ACF) Tape
#11 |
My Country: Canada
![]() https://www.dexerials.jp/en/products/acf/cp20000.html
150-200degC bonding temperature. Vulcanizing tool for tires comes to my mind, it applies both pressure and temperature. Will need metal adapter piece of right shape. ACF is available on aliexpress. Ready for challenge? |
#12 |
My Country: Ireland
![]() So I got the microscope and I resoldered the cable. I must of had it slightly offline because when I powered it up the ribbon cable heated up and burnt a little hole. It must of shorted out. It can be done but I failed on this one Im afraid.
#13 |
Technician
City & State: Near Savannah Georgia
My Country: USA
![]() I have had success soldering some of these flexible ribbon cables (when it's the end that attaches to the board as opposed to the glass that has come loose).
Don't make me dig up the pictures...
__________________
Learner |
Thread Tools | |
Display Modes | |
