Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 01-08-2022, 12:59 PM   #1
Alexbp
City & State: Siegburg
My Country: Germany
Default Whirlpool washing machine L2158 control board
Whirlpool washing machine help determine the resistance r085
I will be very grateful
Alexbp is offline   Reply With Quote
Old 01-08-2022, 01:10 PM   #2
petehall347
City & State: worcester
My Country: United Kingdom
Default Re: Whirlpool washing machine
looks like brown black green gold
1M Ohms 5%
Old 01-08-2022, 01:40 PM   #3
Alexbp
My Country: Germany
The board shows 9 MOm
thank you so much
Old 01-08-2022, 02:28 PM   #4
stj
stj's Avatar
City & State: Europe
how many times did it blow up?
i'm sure the factory didnt socket the psu chip!
stj is online now   Reply With Quote
Old 01-08-2022, 02:47 PM   #5
Alexbp
My Country: Germany
I don't know how much, and I soldered a socket to make it easier to change later.
Old 01-08-2022, 03:57 PM   #6
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Looks like something blew inside the socket?
Old 01-08-2022, 06:06 PM   #7
stj
stj's Avatar
Default Re: Whirlpool washing machine L2158 control board
blew in the socket and incinerated an inductor so hard it burned the electrolytc next to it!
Old 01-08-2022, 06:38 PM   #8
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
What’s the part number on the IC?
Old 01-08-2022, 06:41 PM   #9
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Sorry, but I just had to
Old 01-08-2022, 07:41 PM   #10
R_J
City & State: ☻
My Country: Canada
The part number is LNK304PN. The socket pin (pin6) that is burnt should not have a connection.
The repair kits have other parts that are likely also bad.
R_J is offline   Reply With Quote
Old 01-08-2022, 10:23 PM   #11
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
Heh. Frying a ¼W 1MΩ resistor by itself tends to need to exceed voltage rating for dielectric strength as well as thermal limits at the same time...
Then again, if it fails dielectric strength along the outside, then it'd dissipate less power internally...
eccerr0r is offline   Reply With Quote
Old 01-09-2022, 09:18 AM   #12
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Maybe the IC was inserted the wrong way around or a solder blob... bent pin etc.
Old 01-09-2022, 09:58 AM   #13
stj
stj's Avatar
maybe the chip has the same weakness as TOPswitch's and oscillates itself to death if the startup cap is poor.
Old 01-14-2022, 03:38 AM   #14
SeSeBe
City & State: Iasi
My Country: Romania
The pin gap from the package MUST be removed from the socket to.
Is removed because of high voltage isolation necessary there and more, with pin removed is easy to not insert the IC wrong.
SeSeBe is offline   Reply With Quote
Old 01-21-2022, 03:04 AM   #15
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
It's not a good idea to socket PWM-FET ICs, because they use the Source/return and Drain leads for keeping the IC cool. In a socket, this won't work and the IC will overheat.
Badcaps.net Technical Forums © 2003 - 2022
