Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Old 01-25-2022, 05:28 AM   #1
Fabbrone
City & State: turin
My Country: italy
Default Asus prime B365-Plus No PS2 or USB
Hey
On this mobo with no power to USB or PS2 Port.
what would you suggest?
Thank
fabbrone
Fabbrone is offline   Reply With Quote
Old 01-25-2022, 06:33 AM   #2
DynaxSC
City & State: Parcela/Mazowieckie
My Country: Poland
I'm a: Hobbyist Tech
Default Re: Asus prime B365-Plus No PS2 or USB
Check any Bios setting for swithed off ports, check 5V regulator supplying the USB/PS2 (usually an analogue one) and if the supply voltage for it is presesent (probably 12V). Check for short after the 5V regulator. Check any recovering fuses or any 0 ohms serial resistors in the 5V power lane for discontinuity if present. Check any switching mosfets between the regulator and USB. Check ESD surge protectors on USB data lines for shorts (very small 6 pin dual in-line devices near the USB Ports), they go short on a surge to protect the chipset and must be replaced (they are usually devices like IP4220CZ6, case type: SO6 (SOT457)).
DynaxSC is offline   Reply With Quote
