#1 |
City & State: Athens
My Country: Greece
![]() hello everyone i have this tv and it uses 4 spacers as in the photo which hold the reflection sheet and on which sit the 4 light guide sheets
the problem is that two of them broke on the edge resulting in an unevenness in the height at which the light guides sit My question is these spaceships does anyone know what their purpose is? is to protect the screen? why do not bright spots appear? can I take them out completely or cut the other two to the same height all? thanks in advance |
#2 |
City & State: midwest
My Country: U.S.
![]() they keep the sheet from sitting right on the leds and burning the sheet, hopefully you can source some replacements, they are really easy to break, I broke a few, very easy to do, they also get brittle with age.
#3 |
My Country: Greece
![]() very nice sir
because I can not find and now the sheets are sitting crooked and half the picture is darker than the other I think this has created this issue If I cut the other two normal pieces to the same height as the broken ones I will have some issues from your experience; type bright spot or else? however, the sheets will not sit on the ledges and with the new height |
#4 |
My Country: U.S.
![]() Thats a good question, have not had that situation before, I dont know if there would be any problems or not.
#5 |
My Country: Greece
![]() However, a salesman who unfortunately did not have them anymore told me that it is to protect the screen from small children not to push it and that if I want I can take it out completely
I just asked for sure why the TV is 49 inches and is a bit difficult to open |
#6 |
My Country: U.S.
![]() I think the salesman misunderstood, they hold the reflector sheet in place, so they are necessary.
#7 |
My Country: Greece
![]() would just rather have an experienced technician tell me that to make sure I do not want to experiment
so please if anyone has come to the same position as me to answer me if there is a problem if I remove the spacers completely or if I shorten them all to be the same height |
#8 |
My Country: U.S.
#9 | |
City & State: Midlands
My Country: England
![]() Quote:
#10 |
My Country: Greece
![]() thank you so much for the reply
so now because i put them with different height I have half the picture dark and half light I hope the panel has not been damaged I think because I have thrown the broken pieces to heat the existing piece on the edge to pass a very thin wire and stick it with a strong acrylic glue for sure and cover the wire with white heated spaghetti do you agree? |
#11 |
My Country: England
![]() Yes, it might leave a shadow or dark spot but using wire should work.
You could also cut some triangles from acrylic sheet. |
#12 |
City & State: ☻
My Country: Canada
![]() If the tips are broken, try slipping a piece of plastic drinking straw over the tip and cutting it to the correct length.
#13 |
My Country: Greece
![]() I decided to get M3 metallic screws with thread and washers to be held in the sheet metal of tv
the only problem is that I do not remember the exact length and in addition because they are black and they look like shadows if I spray paint them white I think I will not have a problem right; |
Thread Tools | |
Display Modes | |
