Old 06-30-2022, 11:01 AM   #1
romisek1990
City & State: Borkovany
My Country: Česka Republika
Default Panasonic TX-L32E5E doesnt turn on.
I'm coming to you for advice. On my desk I have this TV that does not turn on. When the TV is plugged into the network and the POWER ON button is pressed, only the red LED is lit.
I checked all the voltage on the P-BOARD:
6V - stynd by
16V
40v backlight
I found out that I can't get a voltage of 12V on the T-CON. Power supply 16V to the circuit IC4101 goes, I just do not know if this circuit controls the processor IC8000. Do you happen to know anyone ?
Thanks for help.
romisek1990 is offline   Reply With Quote
Old 06-30-2022, 11:21 AM   #2
romisek1990
Default Re: Panasonic TX-L32E5E doesnt turn on.
On pin 14 of IC4101 is 5V so it is OK ( no fault ), but I dont have PANEL_VCC_ON and BL_ON why :-( :-( :-(
Old 06-30-2022, 11:45 AM   #3
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
Some good pictures of boards and connectors would help.
dskall is offline   Reply With Quote
Old 06-30-2022, 11:54 AM   #4
romisek1990
A- bord is TNPH0992
P-bord is TNPA5596
pictures I will supply
Old 06-30-2022, 12:17 PM   #5
romisek1990
Some pictures
Old 06-30-2022, 12:20 PM   #6
R_J
City & State: ☻
My Country: Canada
Does the power led flash a code?
R_J is offline   Reply With Quote
Old 06-30-2022, 12:51 PM   #7
dskall
dskall's Avatar
My Country: usa
Is your processor chip intact?
Old 06-30-2022, 01:10 PM   #8
romisek1990
No only light
Old 06-30-2022, 01:11 PM   #9
romisek1990
procesor is visually fine
Old 06-30-2022, 03:22 PM   #10
dskall
dskall's Avatar
My Country: usa
Does your led come on in standby? Does it blink when you operate remote?
Old 06-30-2022, 05:04 PM   #11
dskall
dskall's Avatar
My Country: usa
Do you have data sheet for IC4101. Looks like processor enables it. Maybe heat up processor and try and turn tv on.
Old 06-30-2022, 10:12 PM   #12
romisek1990
Yes, LED light and blinking on using remote. Firmware problem ? TV doesnt boot system?
Old 07-03-2022, 01:06 PM   #13
romisek1990
Is it problem change memory?
Badcaps.net Technical Forums © 2003 - 2022
