HiSense 55HtB power supply bench test: weird voltages
  • MrCreosote
    • Dec 2005
    • 31
    There was a power surge at home from "direct" (no sound delay !!!) lightning strike. Popped a 15 amp breaker for ceiling lights (old knob and tube wiring - perfect antenna?) "Fried" garage door opener buttons and remote, KVM switch, Magic Jack, and a ceiling fan motor.
    And my 55" 6 year old Hisense Black Friday Walmart TV.
    There is no Red standby LED.
    I was wondering how to "jumper" the board on to test voltages thinking the STB pin would be one of the pins.
    However, I decided to measure voltages at all 10 pins just so see there was something there to power the standby switch. What I found was something I cannot explain: Voltages with no power connection to board. Now I was working under 4 compact fluorescent light bulbs but that is a reach.
    Maybe this is telling me the board is fried?
    I have the board pinouts and the voltages are (line cord unplugged) / (line cord plugged to outlet) which is beyond my pay grade. Tried 2 different multi meters.
    1 gnd
    2 gnd
    3 pwm -0.2v / -2v
    4 sw
    5 12v
    6 12v
    7 stb
    8 gnd
    9 18v 22v / 24v
    10 18v 22v / 24v
  • MrCreosote
    • Dec 2005
    • 31
    Re: HiSense 55HtB power supply bench test: weird voltages
    OK found the following definition of the unrecognized pinouts. Also appears this board does not have a 5v standby. Here is a copy from another thread:
    Where is the 5V pin on this board? I do not see one.
    https://www.badcaps.net/forum/attachm...3&d=1472170236
    STB = PS-ON
    SW = BL-ON
    PWM = PWM dimming
    RE: Measured Voltages: the 24v is troublesome: much higher than the 18v spec'd.
    Also, the voltage measured with no power to board could be caps still charged up? But I repeated measurements w/ and w/o power and the values alternated between 22 and 24. If charged caps, I would expect 24 and 24 or the 22 would would change with time while discharging. Could get a VOM to put a little load on it.
    • lotas
      • Jan 2016
      • 4540
      • Russia
      STB is the standby power supply (voltage DC5V).
      STB can be 3 - 6v DC
      • lotas
        • Jan 2016
        • 4540
        • Russia
        PWM - backlight level
        SW - switching on the main power supply 12V and 24v.
        no load and will jump power to 24v.
        • MrCreosote
          • Dec 2005
          • 31
          Both STB and SW are 0v.
          So I've go NO standby power supply and the 18v pins are running 24v.
          RIP power supply board.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            I would not worry about 18V being 24V for now. The standby section should be fixable, it should be nothing more than replacing the switching IC, startup resistor and associated capacitors and maybe the optoisolator.
            A working TV? How boring!
            • R_J
              • Jun 2012
              • 9535
              I answered this in your other thread, The power supply board is working fine, it does NOT supply a separate standby 5 volts
              STB is an input which requires a high (+3~5v) to fully turn on the main power supply and pfc circuit. SW pin also requires a high signal to turn on the 12V_VCC for the backlight circuit
              • nono34
                Hisense stuck in Colors cycle like test pattern.
                by nono34
                I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                10-24-2024, 04:31 PM
              • Eniaro
                Bench test a series X
                by Eniaro
                How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
                06-17-2025, 01:46 PM
              • RossMoodley1967
                HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                by RossMoodley1967
                Hello
                Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                03-01-2024, 06:07 AM
              • redbaron1007
                Yamaha HTR-3065 No power/No Standby
                by redbaron1007
                I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                S9 13.7V
                Pwr Ry 0V
                AC Det 9.1V
                Mgnd 0V GND
                The two pins on the transformer for the operation...
                09-12-2024, 03:04 PM
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
