Old electrolytic capacitors
  • alfredo2j90
    • Oct 2021
    • 4
    So as most of us know, old unused electrolytic capacitors are unrealiable due drying out and breakdown of the oxide layer.
    I have a few questions regarding these issues.
    1. Does using an electrolytic cap stop it from drying out or is it natural process that happens regardless?
    2. With the breakdown of the oxide layer the ESR will increase as well as DC leakage. Say the cap has remained unused on a motherboard, psu or games console for many years, if the cap does not physically pop when power is applied what other damage could occur to the system if it was powered? Does the increased ESR and DC leakage damage the mobo, psu or games console or is the repair as simple as replacing the cap?
  • AleXis6
    • Feb 2021
    • 69
    • Belarus
    Re: Old electrolytic capacitors
    1. As a read producers adviced to keep capacitors in ziplock packs to prevent shortage of their life
    2. I bought LCR meter and evaluate the capacity, ESR, Z, D and other parameters and compare measured numbers to datasheet.
    DC leakage is easy to measure just with a millivoltmeter.
    Capacitors with high ESR will not necessarily fail immediately, but the operation of the equipment may be unstable, the symptoms will increase over time and under heavy load. If you replace a bad capacitor in time, you do not need to change the other components.
    • RetroComputingGrotto
      Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
      by RetroComputingGrotto
      I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
      As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
      What is your advice/opinion on whether or not on old(er)...
      04-03-2024, 08:30 AM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
    • SwedishDiesel
      Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
      by SwedishDiesel
      Howdy folks,
      I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
      10-30-2021, 12:47 AM
    • proxneo
      Recapping Sony ICF-SW55 - verifying cap values
      by proxneo
      Dear reader
      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
      At the moment, I have selected replacements based on the following list of values:
      3 x 470uF 10VDC
      3 x 4.7uF 35VDC
      4 x 47uF 50VDC
      8 x 22uF 6.3 VDC
      1 x 220uF 6.3VDC
      5 x 100uF 6.3VDC
      Which...
      06-21-2023, 12:38 AM
      by sam_sam_sam
      After all of...
      07-13-2024, 08:14 PM
