HP DMI Tool NBDmiFit
    Re: HP DMI Tool NBDmiFit
    Originally posted by Miquell210 View Post
    Hello all.
    This is my first post as new user so hello all.
    Got similar problen with my laptop HP-15-r101na.
    After replacing motherboard receiving three error which I expected to easly fix.
    Well - not really.
    Can find proper tool to do so.
    1. System Board (00A) - Product Name
    2. System Board (00A) - Product Serial Number
    3. System Board (00A) - Product Number
    The only one think able to do was to update BIOS to version F.45
    Then I`ve tried to use different version of NbDmiFit with error platform not supported
    According to HP Serial Number Repository (Product Configuration Tracker) laptop was manufactured in 2014 so I`ve used tools supporting in theory this model - but platform not supported appear in DOS, Windows, WindowsPE
    Can you recommend proper tool or any idea what I am doing wrong, please.
    Post here bios dump if will fix.
      Already tried:
      - HP BIOS Configuration Utility (BCU) - unsuccessful
      -- wndmifit is not common to download - most of download links are going to 404 error or contain fake files - tried so far v 2.09 then v 1.1d to 1.14D
      I am keep looking
        Already tried:
        I am keep looking
          wndmifit is included inside the nbdmifit folder. Page #1 post #1 of this thread has different nbdmifit versions,try 2.10 in UEFI.The site is working ok, no 404 pages for me. You can post your bios in the "Bios Requests" sub forum if you want someone to try repair it for you - https://www.badcaps.net/forum/forumdisplay.php?f=40
            Originally posted by SMDFlea View Post
            Use HP bios config utility BCU ,and/or wndmifit from windows or nbdmifit from UEFI flash drive . Use version 2.10 or above.
            Job done.
            WnDmiFit 2.07 working properly - all data changed successfuly.
            All done by creating pendrive in Rufus and used DOS version.
            Source I faund here:
            https://aiotutorials.wordpress.com/tag/wndmifit/
            Thanks for help all.
              Already tried:
              I am keep looking
              Now you done is good i done always via bios dump modified this type error.
                Hello, I have an elitebook 9470m. I purchased a new motherboard and installed it. I have the error with the alert: "machine not in committed state"
                I'm not sure how to go about fixing this, as I have read online many people have this problem with new motherboards. Windows boots and functions normally. Does anyone know if I can fix this with software? A new part is nice, but am I better off returning the motherboard for a used one?
                  Job done.
                  thank you very much for sharing
                    okay, so I've used the tool, and I've learned that I now need 2 things; the "Feature Byte", and the "Build ID".
                    My own bit of research tells me that the feature byte is a long, case sensitive string of letters and numbers and it looks like this:
                    2U3E3X47676J6S6b727B7H7M7R7S7W7m7saBb3da.3Y
                    (this feature byte is for a ProOne 600 G2)
                    As for build ID...
                    I can't commit the board until I enter these last two fields! Does anyone know how I can find that info?
                    I have a 9470m i7 motherboard with HD+ graphics (1600x900)
                    also, classic bart mooning smilie? heck yes!
                      Does anyone have a newer NBDmiFit? I have a 450 G5 that I got a replacement board from HP for and I don't think any in this thread are new enough.
                        [QUOTE=Skunch;976137]okay, so I've used the tool, and I've learned that I now need 2 things; the "Feature Byte", and the "Build ID".
                        As for build ID...
                        Go to this site and enter your serial and country.With any luck the feature byte will be there.
                        https://partsurfer.hp.com/Search.aspx
                          Use HP BCU, bios config utility.
                            Tanks
                              Originally posted by ala_borbe View Post
                              hello
                              over the years i collected some versions of DMI tools for hp
                              and i wanted them to be all at one place
                              take note that some version are not correct (limited information, missing readme etc)
                              for some laptops you need older, for some newer but there is plenty here
                              also, you need to use this tool in dos
                              and there is Manufacturing Program Mode Error solution here since it is related to bios programming
                              enjoy and remember to share versions you have or related fixes
                              there is a tool for hp 430 G6 ¿?¿
                                https://drive.google.com/drive/u/0/f...KyclbyYaMa0d7F
                                try 2.14
                                  Originally posted by Aditya11ttt View Post
                                  my MPM is locked,
                                  how to unlock my MPM¿,
                                  please give me tutorial
                                    my MPM is locked,
                                    https://www.youtube.com/watch?v=9T57ktw8n3Y
                                    https://www.youtube.com/watch?v=r2ubpyeUOB4
                                    Read the pdf manual as well in the first attachment in this thread on page 1:
                                    Manufacture Programming Mode in Unlock mode MPM
                                      this guide is to LOCK the MPM,
                                      i want to do the opposite,
                                      i want to change the value of my motherboard from LOCK to UNLOCK to change my serial number
                                        my MPM is locked,
                                        upload ur old dump plz
                                        MOD EDIT: NO dumps in this thread, Upload to the bios requests section: https://www.badcaps.net/forum/forumdisplay.php?f=40
                                          Its both,just need to edit the * next to lock or unlock.
