ACER Z1402 on around 10 second and off
    Checked 19v, 3v, 5v, 10.5v, etc seem ok. i found one problem on switch button has 9.55v.
    Try change Q7 and Q57 ic. but problem still exist, any suggestion? does the problem come from EC controller ic?
    Re: ACER Z1402 on around 10 second and off
    Have you solve the problem? Mine also have the same ptoblem.
      same problem too
        can you please tell us the original problem..so that we can relate.. and what have you done so far...any schematics for this unit..
        Never stop LEARNING because life never stops TEACHING!
          The schematic is already posted - https://www.badcaps.net/forum/showth...ighlight=Z1402
            ok did you check the on of switch? if the switch is open you get 3.3v if its close you get 0v
              Did you solve the problem. I got mine same problem 9v on power switch
                https://www.badcaps.net/forum/attach...3&d=1537151559
                check all the mosfets.. switch must be 3.3v when open and 0v when closed..
                  9V sounds ok there.
                    9V is ok like piernov say : resistor divider .
                    Check Q7 , R174
                      check 19v power rail is present or maybe shorted and check the 3.3v and 5v are present if present all if the problem is not exist put the thermal paste and clean the fan if dirty thank u hope u help my suggestion
                        Anyone solve this problem?
                          post your voltage readings(VIN, 3/5VALW, powerswitch)
                            Thanks reply. My problem same like this...
                              What is the problm if PWM_IN 3.3v is drop going to 0vdin the picture of screen is problm also.?
                                i found problem same too
                                  Everybody has same problem with mine too. Any suggestion or solution do you have? Wait for any response. Thank you.
                                    Anyone who solve this problem? any suggestion?
                                      Did you gays check the y2 (32.7khz)? Not done but not any improvement from change y2. So any further movement.
