How to solder in CPU VRM area?
    Well, yeah, how do you solder in that area?!
    I have the LF-8800 (de)soldering station but I'm somehow unable to desolder an unused cap space (get rid of the solder in those holes).
    Desoldering caps works somehow, not great but I can live with that result...
    Is there anything I can do to get rid of that solder in that hole?
    I also tried some (rather cheap I think) solderwick - not much luck with that either...
    Re: How to solder in CPU VRM area?
    heat the other side with hot air or an iron.
      Add some 63/37 pb solder to lower the melting point of the lead free solder.
        Thanks stj, will try that next time...
        @clearchris
        I only have PbSn40 here
        And SN60PbCu2/zh
        But that board was pre RoHS anyway
          I use ordinary transformer solder iron and dental explorer. This or similar
            @clearchris
            And SN60PbCu2/zh
            Yeah, any Pb solder will lower the melting point of lead free solder. 63/47 just has the lowest melting point of the pb/sn solders.
