How much work will this require?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    It's a very old board, also the size is a bit big too
    • 30978
    Re: How much work will this require?
    looks like an oil refinary!
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Fine to run as-is, just remember to water it regularly or the plants might die...
      • PeteS in CA
        • Aug 2005
        • 3579
        • USA, Unsure of Planet
        An artifact of Houston's humid climate?
        PeteS in CA
        • hollox123
          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
          by hollox123
          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
          1. Laptop keyboard doesn't work
          2. The backlight on the laptop keyboard doesn't work
          3. The x2 side LEDs (red) on the laptop don't work
          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
          But I am strongly aiming that it is somehow a BIOS-related problem,...
          05-11-2025, 08:05 AM
        • resistor83
          lenovo 330s-15ikb, led num lock key always on and numbers don't work
          by resistor83
          hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
          I tried updating the bios but the problem remains
          https://s...
          05-29-2025, 08:06 AM
        • flibidy
          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
          by flibidy
          I have here a Magnum IA.100 which belongs to my parents.
          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
          What Ive done........
          01-01-2025, 01:26 PM
          DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
          by sam_sam_sam
          I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
          If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
          One —>the LEDs might be bad
          Two —> the buck converter or regular might be bad
          Three —> the controller might not...
          08-08-2023, 05:12 PM
        • Rhaverz
          My touchpad doesn't work, Asus laptop motherboard X455LJ REV 3.1
          by Rhaverz
          Good afternoon friends
          I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
          I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
          I even checked that the data bus made a connection between the touchpad and the motherboard and everything...
          03-30-2023, 03:56 PM
