#1 |
City & State: ankara
My Country: turkey
![]() hi. psu works, but it was loud and filthy so I opened the case to dust it.
2 caps in the picture has a transparent yellow stuff on top of them but I'm not sure if they leaked or it's some kind of glue. psu1.jpg |
#2 |
City & State: ☻
My Country: Canada
![]() That is glue, remove the glue from the one next to the coil to see if it is bulged under the glue, if the top is flat it is likely ok but you can not tell just by looking.
What was loud? noisy fan? |
#3 | |
My Country: turkey
![]() Quote:
3: Conicon 1005 - 1000uf 10V (1) and (3) looks slightly bulged, 2 isn't. I bought 2 no-name 1000uf25V caps from local store but I'm not sure they'd be fit as low esr replacements. Also wondering if I can install something in place of C42 which was left empty in factory. psu2 (copy).jpg yes, fan runs very fast and loudly. If I can't find a silent replacement fan I'm thinking of undervolting it by splicing from the 5V line. |
#4 |
My Country: turkey
![]() Found an analysis of the psu here: https://www.overclock.net/threads/li...ld-fly.769505/
#5 |
City & State: ☻
My Country: Canada
![]() Yes those two caps are bulged, and are bad, that is usually due to being close to the inductor that will run fairly warm, The cap at location C42 is likely parallel to one of the other caps, and not required. You may want to replace those two small electrolytics next to the coil as well, they won't bulge like the others but will just dry out from the heat.
#6 |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
![]() The cap you labeled #1 is next to an inductor that could get hot and a pre-load resistor that is also dissipating heat. I suggest leaning the resistor a bit farther away from the cap.
Since L4 and L5 have been replaced with jumpers, that P/S probably has very poor spike noise. I recommend looking on the primary side at the capacitors Line-to-chassis and Neutral-to-chassis. If they are there, they should be safety agency approved parts. If they are rated for 1 KV or 2 KV DC, that is a safety problem. Glancing through that linked review, calling it a turd may be an insult to turds. The review sample had the dangerous DC rated Line- and Neutral-to-chassis - "Y" - capacitors. If the primary side capacitors really are 470uF, they might be adequate for 250W. The MJE13007-clone transistors and heatsinks might be adequate for 250W. It sounds like the main transformer is small for 250W, though, so 200W would be a more realistic maximum continuous output power. Safety agency approved Y capacitors could replace the cheapies, 560uF or 680uF capacitors could replace the 470uF types, the switch transistors could be replaced with MJE13009-clones, more honestly rated output rectifiers could replace what is there, good quality output capacitors could replace the Canicons, and ferrite rod inductors could replace the jumpers at L4 and L5, but the main transformer would still limit the realistic continuous output power to ~200W.
PeteS in CA Power Supplies should be boring: No loud noises, no bright flashes, and no bad smells. **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. **************************** Anti-Covid-Vaxxer pig crap claim/prediction, Doctor: Heart Failure from mRNA Jabs "Will Kill Most People" | Principia Scientific Intl. ; Dr. Geert Vanden Bossche Warns COVID-19 Jab Injuries and Deaths Will Soon "Collapse Our Health System" (VIDEO) ; Fully Vaxxed May 2021; Since that time I've done 13 5Ks, 1 8K, 12 10Ks, and 4 half marathons Last edited by PeteS in CA; 03-29-2023 at 04:37 PM.. |
#7 | |
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
![]() Quote:
Is it a game to try to make the device as dangerous as possible? Certainly when you watch some videos from Big Clive you might start believing so...
"The one who says it cannot be done should never interrupt the one who is doing it." |
#8 |
My Country: turkey
![]() Here I present CY1
![]() psu3.jpg psu4.jpg I'm starting to think maybe it's better if I'd re-assembled this without any recap and only use it as power source for the tire inflator from now on ![]() |
#9 |
City & State: ----
My Country: Sweden
#10 |
My Country: turkey
![]() it has only 1 leg left other one looks burnt. psu still works splendidly, though.
#11 |
City & State: ----
My Country: Sweden
![]() Yea now I see it, there is one behind it that appears to have exploded too.
This is a prefect example why safety rated capacitors are required here. But also why it is so idiotic to put regular ceramics: they can just be left out and the thing will work fine anyway! Chinese crap. |
#12 |
![]() A PWS can work OK without all those common mode inductors, X caps, and Y caps, but other electronic products, like TVs and radios, might be affected by conducted EMI.
#13 |
City & State: ----
My Country: Sweden
![]() I know I know, but you think these Chinese seller test for conducted EMI before putting the thing on the market? Lol of course not!
![]() Here is a link hinisa for proper safety rated capacitors. But you should check that they have the correct lead spacing, and also capacitance rating. But it gives you an idea what they should look like ![]() https://www.digikey.com/en/products/...2M-VKA/6124900 |
Thread Tools | |
Display Modes | |
