desoldering station suggestion aoyue 474+ vs aoyue 474++ vs csi 474a
    Re: desoldering station suggestion aoyue 474+ vs aoyue 474++ vs csi 474a
    I looked at the csi model. Looks ok, but really, its a gamble, just like when i bought the ++. There were people here who thought it was a really bad idea.
      csi has a few irons - one is a hakko FX951 rippoff that looks pretty good.
      http://www.circuitspecialists.com/le...g-station.html
      and in a nicer case:
      http://www.circuitspecialists.com/so...-bk3000lf.html
      these are a bit special because the element,and sensor are combined in the tip - they are the best type of design.
      watch this link, it shows how fast these iron's work.
      https://www.youtube.com/watch?v=u588...ature=youtu.be
      if you get the nicer one,
      you can build this later!!!
      http://dangerousprototypes.com/forum...p=61175#p61175
        well should i invest in a digital soldering station maybe from csi and also a desoldering digital station?....or do they make combo soldering desoldering stations
        what i have now is pretty sad...lol
        an upgrade is needed i believe....
          stj what about this one?
          http://www.circuitspecialists.com/csi_premier_75w.html
          as compared to the one from csi you suggested
            no, that's shit.
            i'll put this simply.,
            there are 2 basic types of iron - not talking about the controller here, just the iron.
            there is the traditional type with a tip that slides onto or into the element.
            most are old hakko 900 series clones inc the one you just linked and most aoyue etc.
            then there are professional irons that have a special all-in-one tip that contains the sensor and element in one.
            these heat up faster and can work on large joints like motherboard capacitors that traditional irons have problems with.
            they are hakko T12/T15, pace and JBL mostly, but the T12/T15 has been cloned and the tips are very cheap.
            i would only buy that type of iron now.
            watch that video i linked.
              watch this comparison of the 2 irons on the same base.
              https://www.youtube.com/watch?v=cVrMjr0eCC4
                The problem with cheap de soldering station are the life span of a tip is very short
                spend a bit more and get a hakko 808 or new version
                  tips are cheap, and it's down to how you treat them.
                    hi thanks but no way in hell im going to spend 250.00 on a desoldering iron such as hakko 808
                    this is a hobby for me....not serious or career
                    im looking at the csi brand from circuit specialist or blackjack/aoyue from sra
                    i do apprdciate all input as i am dumb when it comes to this subject and just want to make a good decision
                      I wouldnt say the problem with cheap/clone tips is lifespan. My problem with cheap tips is that they transfer heat poorly. I put some ebay tips on my hakko 888 and they are all but worthless. They take too long to heat up, then you solder a joint or two and the tip is cold again.
                      Those ebay tips will last forever, because they dont get any use...
                        hey stj tips are not cheap with the soldering station unit you recommended ..they are 12.00 each as compared to only 4.00 each for other style....
                        i really dont care about how fast it heats up....not important to me....is it that important to have the tip and sensor all in one piece?
                          you can get those T12/T15 tips on ebay for about the same as you listed for the M900 type tips.
                          and yes,the all in one type can solder stuff that is too big for normal irons.
                          like multi-layer boards and huge copper area's like on pc powersupplies.
                          the speed is important because when the iron touches the joint it loses heat, and the controller has to get it back up to temperature as fast as possible or the solder wont melt.
                            not a problem on the T15 tips even if they are clones.
                            the 888 uses the old 900 series tips.
                            try cutting one in half - see if they are copper core or not.
                            and put a bit of silicone grease on the element before you fit the tip.
                            it helps transfer heat and reduces sticking when you need to remove the tip.
                            btw, everybody needs to read the thread properly before posting.
                            the bit about tip life was refering to de-soldering units.
                              jbl
                              jbc ?
                                my mistake, yes jbc
                                bit difficult to solder with a speaker!
                                  http://www.ebay.com/itm/390685073859
                                  tips under 4$
                                    oh ok.....well on ebay the other style tips sell for 1.00 lol if u go to sellers like the one you posted for the all in ones
                                    anyways i will consider it..but they charge a lot for shipping so i will keep looking for a unit for about 60.00 that has free shipping and digital display
                                    i like the csi2900 but no free shipping so its actually 75.00 shipped not 59.00
                                    and will look for a desoldering station with digital display with free shipping
                                    i dont want to fork out 145.00 for a desoldering station such as the aoyue 474a++
                                    want to keep it under 100.00 total
                                      what about this....if i get the good soldering station csi2900 awill it possibly be good enough to use solder wick to remove the almost impossible ipm chips on plasma tvs that are on multilayer boards with metal pads on top and bottom of board..??
                                        i actually have one of these but have never used it...
                                        http://www.sears.com/weller-174-port...&mktRedirect=y
                                          portasol - it's good that you never used it.
                                          it means you never ruined any boards!
                                          i had one of those bastards - no good for soldering, only setting fire to things!
                                          have you got a 24v psu that can generate atleast 3amps by any chance?
