LF-8800 any good?
    LF-8800 any good?
    So I got anoyed with my ERSA Irons (one older 16W and 1 rahter brutal 150W Soldergun), I decided to get a decent soldering station...
    I'd like to have a desoldering gun, like shown in this video...
    So I took a quick look at what's available here in Germany and I found an LF-8800. Price seems quite reasonable with something under 300 Bucks. And I have the option for a hot air gun.
    So is it any good and worth the money?
    It seems to come with some nice other things...
    Re: LF-8800 any good?
    Assuming that's a Xytronic LF-8800, would be prudent to stock up with spare parts as well
    If my experience is anything to go by:
    https://www.badcaps.net/forum/showthread.php?t=47615
    essential replacements are almost unavailable when the machine is a little older
      Unfortunately there isn't much choice here in Germany...
      The other things I've found:
      http://www.amazon.de/AOYUE-Int474A-E...Entlötstation
      BEWARE: Links are in German. But you get the model numbers...
      Still, since I also need a soldering iron...
      And a Hakko FR-300 isn't available in my region (at least I didn't find a shop)...
        Well, since there ain't no good options, I risked it and ordered it...
        Next month I probably will order a pair of SMD tweezers...
          Got it, used it a couple of times already.
          The Iron is good. What's inside the box is also pretty nice.
          But I have problems with a jammed desoldering nozzle...
          How do I really use such a thing? Is this a normal thing??
            explain "jammed"
              The solder gets stuck in that nozzle, most times right before the filter, where the tip is not heated anymore...
                your not holding the button long enough - it should shoot through the nozzle and splash against the back of the catch tube assembly before it sets.
                have you watched the pace video for vac desoldering?
                  You mean this video?
                  https://www.youtube.com/watch?v=ULWDrF-JEUk
                  Well, now I have, but nothing really interesting is shown...
                    i meant his one.
                    https://www.youtube.com/watch?v=e8KRPFOD1RE
                      Thanks, I'll do that later today =)
                        Well, got rid of the clogging problem. Brute force method: Set Iron Temperature to 400° and more...
