For example, all the stuff at Amazon I found ships from China. I've been through that once, I never got the solder from China. Supposedly "lost" in customs. Ok, I can learn from that. So, where do you guys like to buy solder at?
Where to buy solder?
Re: Where to buy solder?
Ebay or local electronics store.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Ahh right why are you suspicous ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
I am suspicious because I have been stolen from as a result of online purchases. However I don't think I am quite as vulnerable now because I use a prepaid debit card that has no connection to my main bank account and has no more money than I intend to spend using it. I suppose I shouldn't worry but I do anyway.
Buy from Digikey, Mouser or Farnell (Newark.com in US)
Digikey: http://www.digikey.com/product-searc...solder/1310838
Newark : http://www.newark.com/solder-wire
Mouser : http://www2.mouser.com/Tools-Supplie...der/_/N-b11qq/
my recommendation from what i think is best to less best... multicore / kester / stannol/ mg chemicals/edsyn or if you're really cheap multicomp which is farnell's internal brand, it's often rebranded multicore or kester solder but must be careful, just compare datasheet layout with original multicore or kester datasheets. Maybe also alpha metals / aim but i have no experience with these brands as they're mostly us.
63/37 or if you have money 63/36/2 which would have minimal benefits over 63/37, then 60/40 for plain bland generic good solder. No-Clean with 2-2.2% flux or more, but if there's no choice then RMA (rosin mildly activated) would also work, then RA (rosin activated). No-Clean and RMA in the large majority of cases don't require cleaning of the flux, RA is stronger than rma but may require cleaning the flux with isopropyl alcohol after soldering (more work for you). Stay away from solder with water soluble flux, the flux must be cleaned and it's harder than the title indicates, it's misleading.
For diameter, if you have money go with 2 sizes, one about 0.7mm or thicker to feed lots of solder fast when you need to solder something thick, one 0.5 mm or smaller for small soldering jobs. If you're cheap, go with the thinner diameter, you can always bend the solder in two and twist the wires for thicker diameter.
I personally use a 0.56mm no-clean multicore 63/37 with 2.2% flux (if I remember correctly).
If you still have money, also buy a flux pen or bottle, adding a drop of flux before desoldering or resoldering something helps big time, even if the solder has flux included in it. See http://www.digikey.com/product-searc...emover/1311241 or http://www.newark.com/solder-flux or http://www2.mouser.com/Tools-Supplie...lux/_/N-b11wf/ with the same mention, stay away from water soluble flux, match it with your solder wire flux choiceLast edited by mariushm; 09-26-2015, 08:36 AM.
I bought a 100ml bottle for about 3$ from a local electronics shop. It's made in Poland by a company with decent local reputation.
Flux pens are expensive for the quantity of flux they hold but if you only solder occasionally they good enough (as for ends getting messed up, as long as you store them as recommended, they'll be fine).
The stores I mentioned above sell large containers but at steep prices, mostly because flux is considered dangerous to ship by air (it's flammable due to the isopropyl alcohol and other flammable chemicals inside it) so they're shipping them by rail or cars (in theory).
Best deal would be to buy from local stores but you still have to be careful about brand and type of flux before buying. The quality can vary by huge amount between manufacturers.
Desoldering braids for example are perfect examples for this... the flux the copper mesh is soaked in makes or breaks a desoldering braid. Use a good quality braid once and you'll want to throw away all the other braids you have.
I've got enough solder to last me a lifetime I think (a bit less than a pound left now I think, ordered online probably from mcm or parts express or something), but if I had to go local, these stores probably have solder... may not be good solder but it will work...
Home Depot
Ace Hardware
Lowe's
Radio Shack
Harbor Freight Tools (oh no... shipped from China...)
Originally posted by mariushm View PostThe stores I mentioned above sell large containers but at steep prices, mostly because flux is considered dangerous to ship by air (it's flammable due to the isopropyl alcohol and other flammable chemicals inside it) so they're shipping them by rail or cars (in theory).
http://www.rapidonline.com/Tools-Equ...-500ml-85-6650
of course, if your oldschool and just want a bucket of rosin desolved in IPA they have this.
http://www.rapidonline.com/Tools-Equ...-500ml-85-6646
I got some kingbo flux off ebay (china or hk shipped) and it works great. I always clean off flux, usually with brake cleaner.
I ordered some solder off fasttech.com recently, if it arrives, Ill tell you if its any good. Also ordered a solder dispenser, hollow needles and some other soldering goodies. All in it was 20 something dollars.
Thanks for the replies. I think we've got a Lowe's around here now (I hardly get out). I'm ok for flux, I made my own liquid flux out of rosin and IPA and probably won't ever run out. I put it in a dropper bottle but it is slowly eating away at the rubber of the dropper. I'll figure a different container for it.
I'm shocked you went for the Lowe's/Home Depot/Ace Hardware route (they're hardware stores, so they sell general purpose solders, but mostly for copper pipe!) and not Radio Shack. Just make sure you get the "Rosin Core" or "Electrical" solder. Unfortunately they likely will sell you pretty thick solder, like 0.062", and you'll probably not be doing IC work with it unless you're real careful, and likely the rosin in it is pretty crappy. It's also the lead free junk, so expect a bit more heat needed.
It's a pity pretty much all the local electronics shops around here have pretty much dried up. Other options include Fry's (looks like it's over an hour away from Newport, your closest one is near Portland?).
I recall I may have ordered solder from Jameco Electronics which I think is quite reliable. They've been a mail order shop for many years (I've ordered from them many times) and their warehouse is in Belmont, California (I've visited their storefront once or twice too, alas, they will fill your order while you wait). You can get lead solder from them.
Looks like Jameco has switched over to 1-lb rolls of solder... I ordered 1/4 kg and 1/2 lb (by mistake, this was the 0.062" solder) rolls before and each roll is more than I could ever use.
Please research the different rosins (and solder formulations if needed) before ordering a big roll you'll hate I kept the 0.062 misorder because it actually had really good rosin in it as well as being eutectic, and I figure I'll have solder lugs to solder in the future anyway.
BTW I think:
0.5" - for solder pots
0.125" - For copper pipes
0.062" - for solder lugs
0.031" - for through hole PCBs/ICs
0.015" - for SMT repair...Last edited by eccerr0r; 09-28-2015, 06:17 PM.
Originally posted by eccerr0r View PostLooks like Jameco has switched over to 1-lb rolls of solder... I ordered 1/4 kg and 1/2 lb (by mistake, this was the 0.062" solder) rolls before and each roll is more than I could ever use.
i burn through a 250g roll of 0.7mm Sn99.3/Cu0.7 in under a year - and the quality stuff i use isnt cheap.
about $45
http://www.all-spec.com/products/KW4415.html
http://www.all-spec.com/products/KW4410.htmlNever stop learning
Originally posted by SteveNielsen View PostOk, I can learn from that. So, where do you guys like to buy solder at?
My friend, however, swears by solder bought from China. He gets big 1 pound spools of leaded solder for very cheap. Not sure if it is from Alibaba or where exactly.
Originally posted by SteveNielsen View PostI am suspicious because I have been stolen from as a result of online purchases.
Originally posted by clearchrisI always clean off flux, usually with brake cleaner.
I use IPA only, preferably 90% or higher.
Originally posted by stji burn through a 250g roll of 0.7mm Sn99.3/Cu0.7 in under a year
