Sound woofer board damaged/repair
  • nickBcap
    • Jan 2012
    • 114
    • New Zealand
    Hi, I have a Wharfedale subwoofer here for a repair attempt.
    My question is How can I repair the copper track on the board?.....and if you like details please read on. A piece of board track lifted up on the underside of a solder joint when removing a transistor from the board.
    The woofer was making a deep static kind of noise in my flat when I first tested it. When I powered it on it would make a consistent loud humming buzzing kind of noise.
    In the house where it came from it would make a consistent and intermittent and slightly different kind of arcing popping static kind of noise - oh my goodness get it right I can't exactly describe this.
    During removing and testing the transistors the copper overlay on this subwoofer power board beneath one resistor lifted off and I want to repair it. I want to try to join the copper circuit on the board itself.
    I can not tell if I forced the copper off the board trying to desolder the three transistor pins perhaps missing one of the three pins leaving it cold causing the copper to stick to the cold solder, but I think I was being careful to use light pressure to push the transistor out of the board while desoldering.
    I should have used the spring loaded desolder tool first.
    So maybe the problem was that the copper piece that lifted off from beneath the solder joint was already loose, and if I can repair it I will learn if it was already loose beneath that transistor solder joint.
    • 30977
    Re: Sound woofer board damaged/repair
    put a length of stiff copper wire over it.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • karto95
      Repairing a Seagate hard drive with damaged logic board
      by karto95
      I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
      I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
      If anyone has any suggestions or experience with this...
      03-21-2023, 04:05 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
