Thread Tools |
#141 |
City & State: Orangevale, CA
![]() I'm probably the poster child for boring:
Athlon XP 2600, 400 FSB MSI K7N2 Delta2 Pair of 512mb Crucial DDR Matrox G450 dual-head Turtle Beach Santa Cruz Two 500gb Seagate IDE Memorex 52x CDRW Pioneer DVR-109 AHA-2940AU scsi controller for ScanJet IIcx Antec full size case Sparkle ATX-350PN, 120mm fan WinXP, VMware The DNS machine is: Duron 900 8gb Quantum Fireball Fedora 3 The mail machine is: K6/500 FIC VA-503+ board 256mb Crucial PC100 20gb WDC drive Netware 4.1 |
#142 | |
City & State: Valley of the Sun, USA
![]() Quote:
Things must have come a long way when a terabyte of storage is considered boring. ![]() That's a nice system. (I'm a socket-462 fan) And the 503+ is a classic board. I still have one with a K6-3+ 450 in my possession. |
#143 |
![]() I'm also a 462 fan!
![]() And by far this is the only system I play with since ages. There's nothing going on dual's, quad's, extremes etc that gives you half of the excitement as running a nF2 in 2631Mhz at 250 FSB x 10.5 stable using 2222t and CPC on! This is my nF2 hobby system: DFI LanParty NF2 Ultra-B *Taiwan* + lots of heatsinks TT Xaser V Case_Bios Suzuna sx3.8b6 IQYHA 0351 Stepping AXP-M 2600+@2631mhz 1.800vc 10.5*250 sPI 36s Aerocool HT-102 / NB+SB ZM Cooled + Fans 2x512MB Mushkin Redline PC4000 3.20v - Fan+Pencil Mod 11-2-2-2-2-13-15 - WD Raptors_SATA Striping 2x 80GB Lite-On 20Ha DVD-RW ATI Radeon X850XT Vmods@600Mhz_core/1200Mhz OCZPowerStream520W Adjustable SLI Fortíssimo IV 7.1 Soundcard 2631Mhz 250*10,5 Stable! X850XT Voltmoded A3 result And to get passed the 2631Mhz barrier at 250Mhz FSB I recently had my DFI Lanparty recap with Rubycon's and I am also upgrading the system to Liquid Cooling. I plan to get this baby running soon above 2700Mhz. Upgrades Inc: - ATI X1950XT Agp; - Asetek Waterchill Kit KT12-L30; - Recaped to Rubycon's. Started to work with the case: 120mm Dual Rad's 1 120mm Dual Rads 2 My other "normal" systems are so boring that doesn't even worth mentioning... Last edited by Jor3llBR; 07-24-2007 at 11:10 AM.. Reason: t-y-p-o-s |
#144 |
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
![]() Wow Jor3llBR, all respect to you
That is an awsome overclock you have there! I never got more than 2.3ghz or so from my mobile CPU |
#145 |
![]() Thanks mate!
It was fun to get that nF2 to run that on AIRCOOLING! That was the limit, I never wanted to push further then 1.8v in air. But now with Liquid Cooling and new Caps I plan to get things even higher. Do you remember your Mobile Stepping? And whats your Socket A mobo? |
#146 |
City & State: ----
My Country: Sweden
![]() AXMH2500FQQ4C Z40091SB40131
IQYHA 0409RPMW I've used both a Epox 8RDA3+ and a Abit NF7-S with it 2.3ghz was on Air too.... |
#147 |
City & State: Genesee County, Michigan
![]() Are those zip ties holding the fan on that heatsink? That's bad ass how they just latched right in there.
#148 |
![]() Yes, zip ties. The fins of these 60x80mm heatsinks were spaced just perfectly to retain the ends when slid in place. I placed 4 through the fan screw holes and suspended the fan above the heatsink. Once zipped, the tension held it in place while the bending of the ties pushed against the housing. Very secure.
An aside, I discovered the ties isolated fan vibration very well, they act like springs. I installed an 80mm fan similarly to cool my Seagate 400 MB HDD. That fan was a cheap sleeve bearing fan that vibrated when horizontal. But vibrations don't transfer to the case. Zip ties are great! ![]() ![]() |
#149 |
![]() Just received my nF2 system from Topcat the mobo was fine but had a lot of Teapos and OST's that was holding the overclock back.
This 'old' nF2 system was running stable at 10,5x250 (2630Mhz) but I knew I could brake the 250Mhz barrier if I had the courage to send a perfectly working motherboard for a complete class A recap (Rubycons mcz). Of course I couldn't do it myself so I sent the mobo to Topcat and as soon as I received this old platform is amazing me so far (look at the ss's I took today the memory bench timings are running close to a Intel Core 2 Duo e6700!!!!!!!) Also after the recap my mobo is running 10oC cooler! On air cooling it used to be at full load 59oC and now it barely reaches 50oC. So Recap mobos DOES indeed worth the buck! Same system posted above is now running at 2666Mhz amazing 10x266Mhz with 2-2-2-2-2t-9 and cpc ON (cmd1)!!! Impressive to run at those tight timings(at least for me that couldn't get passed 250Mhz): 2666Mhz 1:1 266x10 LOOK AT THE e6700 with DDR2 - I'm almost getting ya! Memtest 2666Mhz New Rubycon's by Topcat My goal now is to keep pushing this above 266Mhz and et it stable at 270Mhz. |
#150 | |
![]() You have a good stepping I think the ony thing you need is a good modded bios for that NF-7 to get it running @ 2500Mhz.
I used to use Tictac's BIOS on my NF-7. Quote:
#151 |
The Boss Stooge
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
Excellent work Elano!! Thanks for the update, and glad its performing well for you, and beyond your expectations!!
<--- Badcaps.net Founder & Owner Badcaps.net Services: Motherboard Repair Services ![]() ---------------------------------------------- Badcaps.net Forum Members Folding Team http://folding.stanford.edu/ Team : 49813 Join in!! Team Stats |
#152 |
City & State: San Jose, CA
![]() Main System:
Pentium 4 2.0GHz Asus P4PE Socket 478 Motherboard 2 x 512MB Samsung PC2100 GeForce FX 5600 Ultra SbLive! with film signal caps--power caps bypassed films Adaptec PCI 10/100 AHA? series WD800 HDD Toshiba SD-M1612 DVD-ROM Antec SL350 PSU recapped with Samxon GC/GD ![]() Antec Value-line Full Tower custom painted (by me) with DBU9700 Black base, Transtar clear and Red metal-flake. Project System(for headphone listening): Pentium 3 500MHz Abit BH6--to be recapped with Samxon GC/GD 512MB Infineon PC133 3dfx Voodoo3 3000 AGP SB16--to be recapped with Panasonic FM and bypassed with films D-Link DFE-530TX Fujitsu M1623-TAU Antec PP-303X--to be recapped with Samxon GC/GD
Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700 |
#153 | |
The Boss Stooge
![]() Quote:
#154 | |
![]() Quote:
#155 |
City & State: Cebu
My Country: Philippines
Line Voltage: 220V
![]() Time to bump this thread?
![]() Intel Core 2 Duo E6420 (2.13 Ghz) ![]() Gigabyte G31M-S2C Mobo ![]() 2GB DDR2-533 RAM (2x1GB) 256MB Inno3D GeForce 7300GT DDR3 80GB W.D. SATA Hard Drive + 250GB W.D. SATA Hard Drive LG DVD-ROM/CD-RW Combo Drive 17" CRT Monitor SilverStone ST400 400w Power Supply Note: Parts in BOLD were the only one I replaced from my previous AMD rig (AMD x2 4000+ AND MSI K9N-Neo-F V3) that lasted from Feb. 2008 to Feb. 2009. ![]()
CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770 GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450 Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1 |
#156 |
Mac Enthusiast
City & State: Chicago! Run 4 your Life!
Line Voltage: 120VAC 60hz
![]() OK, let's BUMP the thread!
![]() Keri's current system: Mac Pro 1.1 Dual 2.66ghz Dual-core XEON (Core architecture) 1.33ghz bus speed 8GB ECC DDR2-667 in Quad Channel configuration ATI Radeon HD2600 Apple EFI-based Server board populated with UCC 4 internal SATA2 drives, 2 in RAID config. (MacOS on WD BlackCaviar 1TB) 1 Pioneer DVD-RW DVR111D DVD burner Delta 980w proprietary Apple PSU crammed full of UCC and a few Taicons Bluetooth Firewire 400, 800 50 lbs of solidly constructed Aluminum Case that puts Lian-Li to shame. Keri's previous system (retired) e6750 Core2Duo 8GB in Dual-Channel configuration ATI Radeon HD3850 Intel DP35DP Media Series board HighPoint RocketRaid 3120 Hardware RAID card 4 internal SATA2 drives, Vista HP on RAID0 2 Plextor 716SA DVD burners Seasonic S12-600 PSU Firewire 400 4 internal SATA2 drives, Lian-Li V1000BW Plus2 aluminum case- (high-quality knockoff of the MacPro/PowerMac G5 case) Maybe someday I'll put an i7 system in the Lian-Li. Or get that new 8-core MacPro. Decisions, decisions... ![]() Have Fun! Keri PS. Why on Earth is an old lady like me playing around with high-powered computers like these? Answer- Non-Linear Video Editing! It's practically impossible to buy a "normal" system that can handle NLE properly. Also, it's fun to shop for all the pieces.
The More You Learn The Less You Know! |
#157 | |
o.O
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
![]() quote from another forum (i posted that earlier there)
pics are not up-to-date but you get the idea ![]()
#158 |
Large Marge
City & State: Kalamazoo, MI
Line Voltage: 0-120VAC 60Hz
![]() Ok might as well...
Gaming rig: AMD athlon 64x2 5000+ 2.6ghz socket AM2 Biostar Tpower N750 (100% solid caps,) 4gb OCZ DDR2-800 PNY 9800GT 512mb WD 7200rpm 320gb single platter Sata HD Realtek 7.1 integrated high definition audio Realtek integrated Gigabit Ethernet Lite-on DVD-ROM/CD-RW Server: 2x Intel Xeon 3.06ghz socket 604 w/HT IBM Z-pro Intellistation 6221, All caps are Rubycon, UCC, Panisonic, Sanyo OScon, even the smallest caps are Panisonic 2gb ECC Registered DDR-266 Power Color Radeon X1650pro 512mb AGP Hitachi Deathstar 60gb 7200rpm (to be replaced by 36gb seagate cheetah 15,000rpm scsi drive,) ADI Integrated AC'97 audio Broadcom Integrated Gigabit Ethernet Compaq DVD-ROM/CD-ROM Lappy: HP Pavilion zd7020us 2.8ghz P4 northwood 512mb DDR-333 80gb Hitachi 7200rpm 8mb cache Nvidia Fx5600Go 64mb 17" widescreen Realtek 10/100 ethernet Broadcom Wireless Conexant AC'97 Audio HL-DT-ST DVD-RW/CD-RW
#159 | |
The Boss Stooge
![]() Quote:
#160 |
Court Jester
City & State: Baltimore-A Rat Hole With A Harbor
Line Voltage: 120VAC@60Hz
![]() Junk Parts has junk parts!
Dell Dimension 4550 Intel P4 2.4 "somekind of wood core" 512 megs 266 Dell Ram ATI Radeon 7000 Video Sony DRU-800-A DVD Burner Gerneric 12x DVD Burner 40 gig WD HD 7200 RPM IDE Dell Optiplex GX 180??? Don't remember Intel PIII 1Ghz 512 megs mixed Junk Ram ATI Radeon All In Wonder 7200 seriers???? don't remember 2 Generic 12X DVD burners 80 gig WD HD 7200 RPM IDE Lappy Dell Latitude C640 Intel P4 M 1.8Ghz 512 megs Dell Ram ??? speed 30 gig HD speed unknown???? ATI 7000 Video ??? 1.44 meg Floppy One Busted CD-RW/DVD-ROM Meghertz 56k Cellular Modem One dead Li-Ion Battery One dead Backup battery Yes Sir we use Xp Home on all our Junk Parts! ![]()
“It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so.” ![]() ![]() Mark Twain "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." John Paul Jones There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone. Rod Serling |
Thread Tools | |
