I work mainly with larger (2000-3000 ball) BGA chips, typically 0.4-0.55mm solder balls. I've reballed many of these, and it's always a royal PITA. My current system is direct heat stencils and hot air, which works but is very tedious. Typically takes me 3 hours, which is about 2 hours too many. And to make matters worse, today i discovered that one stencil must be warped, because as soon as I apply heat, 1/3 of the stencil lifts away from the chip and all the solder balls run together. Unfortunately that's the only stencil I have in that size, atm. You know... we've all had weeks like that.
So, what materials, stencils, flux, techniques, tricks, etc. do you guys use? There's gotta be better ways to do things. Please don't just be all grandiose and vague ("Use better stencils!" without specifying exactly which stencils are 'better' in your opinion, etc.). If you have something that works, I'd like enough information so that I can go buy it myself.
