A good Apple LCD monitor, "Cinema HD Display", 23", model A1082. Doesn't power up. The customer says that has tried with another power supply and it works, so it's a PSU fault. It's an A1097 power brick. Seems expensive enough to try a repair.
It outputs 24V fine with no load, but as soon as you connect the monitor, the voltage starts to drop and rise (up to the nominal 24V) in a 1 second cycle. Monitor's led is off all the time.
I open it with hammer and flat screwdriver (much less destructive than you're thinking, believe me!!). Everything looks fine inside, no overheats, no blows, no bulging, good quality components... No info anywhere in the net, like I'm the first one trying to fix one.
I don't know what to do. Then I see that it has a polyester film capacitor 22nF 630V ("223J 630V" marking) in parallel with the primary electrolytic filter (150uF/450V). This film capacitor is exactly the same guy than the one from Yamaha receivers and sound bars that fail so nicely and that have been spotted years ago.
So, nothing to lose, I change it and... it works!! I'll test it more thoroughly to be sure, but I couldn't get it to work not a single time before, so, what should I think?
