Thread Tools | Display Modes |
#1 |
City & State: durban
My Country: south Africa
I'm a: Knowledge Seeker
![]() Fellow brothers
Kindly assist with the Following: MSI Gaming Laptop Model number: MS-1799 Motherboard no:MS - 16J91 VER: 1.0 The bios chip is shorted, i removed the bios chip from the board but short is still there, pin 8 of the bios chip which I believe it 3.3v it shorted to ground, pin 1 and pin 2 are shorted to ground as well, pin 5 and 6 as well I injected 3.3v on pin 8, nothing is getting hot on the board, i even limited the current to 4 Amps but still nothing is getting hot Again there is coil which is shorted straight to ground, I believe it 3.3v output, still when i inject 1v there nothing is getting hot yet the board is taking 4 Amps Im totally confused Can someone help me please . Last edited by SMDFlea; 05-21-2020 at 05:10 AM.. |
#2 |
City & State: Valbonne, 06
My Country: France
![]() Check if PCH die warms up when injecting on 3.3V rail.
__________________
OpenBoardView — https://github.com/OpenBoardView/OpenBoardView |
#3 |
City & State: NE
My Country: Philippines
Line Voltage: 220VAC 60Hz
I'm a: Professional Tech
![]() You should observe a warming up of component at least, unless the short is below 1 ohms. Also replace the wire you use for injecting 3.3v. You need a larger diameter wire or else, nothing will heat up.
#4 |
![]() highly agreed, im gonna use a larger wire, it 000, straight to ground and my wire is getting hot instead, im gonna change my wire tomorrow and update you guys
#5 |
#6 |
City & State: NE
![]() Check again if your wire is heating up. Shorten your wire if possible. Inspect using microscope if you have, could be a shorted large cap or the PCH is busted. You might need to leave it for 5-15 min and get back to it to check which area is warming up.
#7 |
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
![]() Agreed with others opinion-very likely its shorted PCH.
Thread Tools | |
Display Modes | |
