Hp elitebook 745 g3 (AMD) bios password
    Re: BIOS Password Reset HP Elitebook 745 G3
    Sure. It is under bottom cover.
      Is it the one by the right of the CMOs battery?
      Got other pics if not
        What is written on the one near cpu fan?
          I assume you meam this one as it has a dot on and looks similar to others on yourube!
          Ah that would make more sense...it has an arrow, which I assume is number 1 pin. The ref is CN365 or potentially u365. Depending on what label I'm looking at.
            Can't quite read what's written on it....looks like a serial number. There is some writing that is slightly obscured. inbond with possibly some missing letters in front of in bond.
            Can't get all the numbers / letters. Something like
            128FVPQ 1521
            E103
            41300zy
              Winbond W25Q128. That one is the correct chip.
                Thanks. I'll watch some videos on how to use programmer and then drop my bios on here...all being well.
                Much appreciated- thank you again.
                  Oh, forgot to say that since this is wson8 package, you either need to solder wires to the golden pads or unsolder the chip using hot air station. In the first case you don't need the soic8 clip.
                    I have a heat gun, so probably easier. How do you get back on?
                      Having read properly I assume solder :-)
                        Unsoldering and soldering would be both using a hot air station (do not use a regular paint removing heat gun, it will destroy your board because it usually lacks temperature control).
                        If you dont have a proper hot air station, just solder wires to the golden pads instead. Will be much less destructive. The down-side is that you might have trouble reading/writing properly when doing it like this.
                        Please make sure to verify your dump before doing any writing or just read twice and compare files using hex editor.
                          Thanks. It arrives I'll try solder first. I have a precision soldering iron...I'll try soldering first. Just be the user who don't precision lol
                          Heat gun I have doesn't have heat control.
                            Re: Hp elitebook 745 g3 (AMD) bios password
                            Someone please help. Hp elitebook 745 g3 (AMD) bios is passworded and i dont have the password.
                            What can i do please ?
                              Did you atleast read this topic?
                                Hp 745 G3 6050A2725101-MB-A02 Bios Lock
                                Hp 745 G3 AMD
                                6050A2725101-MB-A02
                                Please clean the password and me region
                                thanks a lot
                                  Re: Hp 745 G3 6050A2725101-MB-A02 Bios Lock
                                  No need to clean ME Region with AMD CPU ,
                                    here you go
                                      could someone help unlocking it please? Thank you.
                                        try..
                                          thank you test ok
