Asus X555 liquid spilled
    Hi, Asus X555LD Rev 3.3 motherboard, with all main voltages and no image.
    After cleaned it and test with a good new bios dump, keeps the same.
    Debug card shows nothing in its display, only the dot led is on.
    BUF_PLT_RST#_R1 on wifi connector is at low level, SM_DRAMRST# is at low level also.
    XTAL 32.768KHZ circuit is working properly but XTAL 24MHZ, (XTAL24_OUT) has 1/3 of amplitud than XTAL 27MHZ (XTALOUT_C) on GPU nvidia oscilator.
    I have the boardview and repair guide fro asus, but need a similar schematic from asus or other brand in order to follow the circuits.
    CPU damaged?
    Thanks for your help.
    Re: Asus X555 liquid spilled
    mostly GPU or ram
      Originally posted by ktmmotocross View Post
      mostly GPU or ram
      I have checked another ddr3L ram module and check temperature of ddr soldered chips and seems ok.
      Also I've removed coils from +NVDD (PL8501 and PL8502) in order to see if it switches to igpu, but keeps with same behavior.
      The current drain from psu is 214 mA. with all coils connected. ( the weird thing is than current consumption is the same with PL8501 and PL8502 removed)
      Another weird thing is the signal H_CPUPWRGD. (this signal is connected from cpu to R0823 and gnd, no other circuit checks this signal)
      Is there a known way to convert from dis to uma?
        Can someone confirm "me" version for this board?
        I have tested a dump with Version: 10.0.38.1000 and another dump with Version: 10.0.30.1072
