Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Appliances and other Household Electronic Stuff
Thread Tools Display Modes
Old 02-26-2022, 06:36 AM   #1
sansonet
City & State: NC
My Country: US
I'm a: Knowledge Seeker
Default Empava KQC65C-17 Built-in Convection Electric Oven - display problem
My friend asked me to check this oven display, its Empava KQC65C-17, and the part is not available even from the manufacturer. On the bottom of the first pic temperature digits have some LEDs off. Im trying to figure out what parts/components could be the culprit so I can test them. Also what connectors I should use to power it on? I only have those two boards in the house, not the entire oven, but looks like it can be powered on from 110 or 220V.
File Type: jpeg c91cc3343968516293afbbb19bb02ed6feffa280-1.jpeg (24.3 KB, 17 views)
File Type: jpeg d96d5f46dd8ea68e0e36b9549676de06df7c9b69-1.jpeg (75.4 KB, 13 views)
File Type: jpeg d96d5f46dd8ea68e0e36b9549676de06df7c9b69-2.jpeg (91.6 KB, 12 views)
File Type: jpeg d96d5f46dd8ea68e0e36b9549676de06df7c9b69-3.jpeg (99.1 KB, 16 views)
sansonet is offline   Reply With Quote
Old 02-26-2022, 07:04 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Built-in Convection Electric Oven - display problem
get a 3v coincell battery and try to light all the segments.
there is a good chance the actual leds are bad.
notice the uneven brightness in the working ones!
stj is offline   Reply With Quote
Old 02-26-2022, 07:31 AM   #3
sansonet
City & State: NC
My Country: US
what points I should use to connect 3V? Should I use 5V/gnd pins on the power board (pic #5)? This connector goes to the display board. I have 5V DC adapters I can use, also lipo batteries 3.7-4.2V.
This is part of the board on the backside of display, top left are connector pins
Old 02-26-2022, 10:39 AM   #4
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Default Re: Empava KQC65C-17 Built-in Convection Electric Oven - display problem
Dose this display pins go to an ic chip of some type if dose then might be a chance that that chip could be this issue or if the display has a multiplex common pin that connects all the diodes to a common negative or positive terminal I have seen these displays do this when they fail
I not a big fan of this type of display
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 02-26-2022, 12:14 PM   #5
sansonet
City & State: NC
My Country: US
Quote:
Originally Posted by sam_sam_sam View Post
I am not a big fan of this type of display
yes, it's only 5 y.o., but useless now without being able to set up the temperature. The manufacturer would not even sell this part because they said it's "too old" and they don't carry it anymore.
I still trying to figure out how to power it up, can't do much without it.
Old 02-26-2022, 01:48 PM   #6
stj
stj's Avatar
the display is matrix driven and the chip is probably a Holtek clone
Old 02-26-2022, 07:13 PM   #7
sansonet
City & State: NC
My Country: US
He sent me pic of how it was wired before disconnection
Old 03-05-2022, 08:52 AM   #8
sam_sam_sam
My Country: USA
I look up this brand and found that there products are not cheap to buy for something that seems to be made in China
$600.00 to over $1000.00 the question I have is how good is there quality for the money and not to offer repair parts is very big problem for me when deciding on buying something like that
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
