Help with IR6500 rework station
  • petemanuk
    • Feb 2022
    • 26
    • Wales - United Kingdom
    I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
    1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
    2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd values. Any tips on where I could find information on this especially the PC410, I know how to set the profile (temp rise rate, temp, dwell etc..) but not the PID loop, same goes for the bottom controller.
    3. When watching various tutorial some mention soaking the board at 150degC for a period of time before running the main profile. I tried this only to find several Electrolytic caps poped as their rated temp is only 105degC, this is after I’d screened them with capton tape. Based on that should I remove all the caps or should I just soak the board at a lower temperature?
    4. When I look at both the top and bottom IR heaters through a thermal imager the heat distribution is so uneven across the elements (hot spots in different locations), it is causing uneven heating of the rework part. I recently tried to remove a LGA1151 cpu socket and found using the thermal imager the socket was around 50degC hotter on one side due to these element hot spots, which caused board damage as when the colder side eventually heated up the hotter side it cooked the board (pop-corned it). Is their any thing I can do to make the heat distribution across my heating elements more even.
    Any help on the above would be much appreciated.
  • shahnld
    wds-580 rework station issue
    by shahnld
    Good day.
    i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
    Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
    kind regards...
    03-28-2024, 01:14 PM
  • minimania
    Need Schematic for jbc am6800 rework station
    by minimania
    hi all im looking for a Schematic for jbc am6800 rework station
    mine has stopped working fully
    it started with turning off when switched on then after a few off and ons it worked sort of for awhile
    now it wont turn on at all...
    01-28-2025, 03:44 PM
  • Peter_1402
    Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
    by Peter_1402
    Hi Everyone,
    I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
    1. Soldering iron works great
    2. There is a burnt mark on the hot air gun handle.
    I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
    Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
    Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
    Reed switch tested ok with a magnet.
    From the above test, I can conclude...
    Yesterday, 11:50 AM
    HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
    This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
    09-12-2024, 02:20 PM
