Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 06-27-2022, 01:15 AM   #1
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Grr... stupid DPAKs.
Guess what I'm trying to do with them.
Tried a 100W gun... no dice in getting it to budge
45W pencil with a big flat tip... no dice
I'm not sure if I want to salvage this transistor or not at this point as I'm not sure if it's the culprit or not... hot air would do any better?
eccerr0r is offline   Reply With Quote
Old 06-27-2022, 02:11 AM   #2
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
Default Re: #@&*%!dpak
Get yourself a better iron like the Axium T3A, if that won't remove it you're doing something wrong.
Are you adding leaded solder? Why not try it with the hot air?
diif is offline   Reply With Quote
Old 06-27-2022, 04:26 AM   #3
petehall347
City & State: worcester
My Country: United Kingdom
I'm a: Knowledge Seeker
Default Re: Grr... stupid DPAKs.
hot air and 60/40 should shift it
petehall347 is offline   Reply With Quote
Old 06-27-2022, 07:01 AM   #4
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
before i had hot air,
desolder and slightly lift each leg
put a bit of solder on the end of the iron and hold it on the tab.
eventually the component will slide down and you can extract it
stj is offline   Reply With Quote
Old 06-27-2022, 07:33 AM   #5
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
holy crap. 200W pencil iron... LOL.
Yes, added leaded solder...hmm.
Old 06-27-2022, 10:28 AM   #6
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Blah, and of course the source pin has a huge pad with PTVs and a through hole capacitor right next to it... Incidentally that capacitor is a solid polymer electrolytic.
Old 06-27-2022, 01:10 PM   #7
petehall347
preheating the board helps
Old 06-27-2022, 04:11 PM   #8
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
hmm... Tried to use my hot air gun on another (scrap) board with a dpak, came right off with no fuss.
I don't think I'll see the same on the motherboard I want to take the mosfet off of (without damaging either -- worried about frying the other components that are right next to it!).
BTW I wonder if I could sub a TO220 in for a dpak and not solder to the board... if the larger package is sufficient for not having board heat spreading...
Old 11-09-2022, 11:13 AM   #9
harp
harp's Avatar
City & State: 45.2,14.4
My Country: Planet Earth
You can desolder dpak with soldering iron, just slightly lift up legs and put some baking paper behind.
https://m.youtube.com/watch?v=Khs6txY6iW4
harp is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
