Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Thread Tools Display Modes
Old 11-15-2022, 09:28 AM   #1
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Rivets (eyelets) in PCBs?!
I noticed some PCB manufacturers insert what appear to be rivets/eyelets in their single sided PCBs. What appears to be silly ways to do PTVs, this is clearly not the case as the board is SS.
So what are these rivets/eyelets for? They make desoldering annoying due to making a gap for solder to come out, though it does provide strength for the pads. Perhaps they were put there specifically to protect the pads? Then why isn't this common practice among all PCB manufacturers?
eccerr0r is offline   Reply With Quote
Old 11-15-2022, 11:38 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Rivets (eyelets) in PCBs?!
it's to make the solder joint stronger - thats why it's on the heavy stuff like transformers
stj is offline   Reply With Quote
Old 11-15-2022, 11:57 AM   #3
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
On this particular board it's on transistors and capacitors too, though yeah I can see transformers and other heavy items... like heatsinks...
But not all manufacturers do this and thus it seems it's not absolutely necessary -- or perhaps this board was meant to be above and beyond other boards...?
Old 11-15-2022, 12:07 PM   #4
redwire
City & State: Alberta
My Country: Canada
I've seen rivets on pretty cheap phenolic PC boards with thicker wires going to the board. The rivet acts like a really strong pad, the wire threads through the hole so the wire's torque doesn't rip off the pad.
I think these rivets are inserted by hand, so not common practice.
I just worked on a really cheap phenolic pc board with rivets to the mounting brackets. Drilled them out but used pliers to pull it out and the board cracked. Hint: drill them right out if you are going to.
redwire is offline   Reply With Quote
Old 11-15-2022, 02:23 PM   #5
stj
stj's Avatar
very common on crt monitors.
Old 11-22-2022, 04:07 PM   #6
RukyCon
A Fake Rubycon
RukyCon's Avatar
City & State: The Peoples Republic of California
My Country: USA
Line Voltage: 122.5VAC 59.9Hz
I'm a: Knowledge Seeker
From what I've seen, these are fairly common on some older LCD TV power supply boards, particularly those made by brands like Delta.
RukyCon is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
