Hi all, I've a Pioneer VSX-859RDS on my desk where the owner tried to improve the sound quality by using the idle current adjuster without a voltmeter.... indeed as the drivers are Mosfets he managed to blown them so the parts needed to be changed as the unit went into protection mode all the time:
- First I ran into the issue that the service manual of the VSX-859 does not contain the power amp diagrams but I found that the Pioneer VSX-35TX does have them included.
- Also found in another forum that parts in the driver stage could be damaged and indeed I found 2 burned resistors > replaced all
- Once I turned the unit back on with all parts replaced, the main fuse blew instead of going in protection mode, replaced fuse to be sure the old one was not weak but new fuse blew as well. Investigation showed that the replacement of Q2542(2SC4137) wasn't an isolated TO-126 housing so installed a mica isolation part > still fuse blew
- Now looking at the power amp PCB I do see a transistor/IC which is not listed/reflected in the SM (Q2552), it's a part with 6 legs, no description on it (see attached photo) and Google wasn't helpfull either. As the part is in the power amp section I just want to replace it to be 100% sure.
Long story but does anyone have any experience with the VSX-859 power amp and has an accurate service manual where all parts are reflected?
Many thanks for your replies and support....
