Hp Probook 650 G2, network port not working
    I have HP probook 650 G2 but the network port does not work. It is not a software problem because the installation is done more times and drivers are reinstalled. It is hardware problem, can anyone help with this?
    Re: Hp Probook 650 G2, network port not working
    Any one? ��
      Originally posted by saidbe View Post
      Any one? ��
      update bios ..
        Network detected and installs properly in device manager??
          yes
            So this confirms that the logic side is working with the PCI or PCIe interface of the ethernet controller reporting their IDs to the host pc.
            Is the rj45 connector for your cat5/6 cable look ok?
            Perhaps the contact pins are mangled?
            Do you see any different ethernet light patterns when you attach the ethernet cable vs. remove the cable?
            Any burn marks near the ethernet connector region? Perhaps an external surge that took this out.
              I too will suggest to replace the RJ45 Connector.
                THANKS for your suggests
                  Gotta check if it has a valid MAC address, if it detects a cable plugged in and if it negotiates speed and duplex properly.
                    bios probleme buddy
