question about TPS51980B at 820-01987
    Hello, the macbook has power issue - stuck at 5V.
    As I cannot find datasheet for TPS51980 [U7650] can someone help figuring out if there is an issue there.
    Voltages of TPS51980:
    pin23 VIN 12.27V
    pin22 VREG3 3.31V
    pin29 VREG5 0V
    pin13 VREF2 0V
    pin12 EN 0V
    so in order to get VREG5 & VREF2 it needs the enable at pin12 and VREG3 is always on?
    Re: question about TPS51980B at 820-01987
    Remove all power. Measure the resistance to ground of vreg5 pin.
    Post the measurement.
      I have already checked for shorts.
      It is 17KOhm
        820-01987 is 2020 macbook right ? 12,3 volt on vin is not good.... it should be around 13 volt.
        dc in is 5 or 20 volt ?
          2020 correct
          input is stuck at 5V so I'm searching for the reason
            5v on charger is totally different problem, not related to tps51980.
            check 3.3 g3hot volt if present, and all ldo volts.
              you are right
              short at PP3V3_G3H
              I found shorted cap at PP3V3_G3H_SSD0 and more short under shield at T2 area
              is seems game over to me
              thank you for your time
                inspect ssd power ic if looks ok or bad... probably ssd got fried and unless u swap ssd nand ur board is dead, but before all that check everything
                  The security chip T2 has issue so there is a no fix.
                  I'm wondering how 2 separate locations have short at the same line, I'm guessing over-voltage.
                    can someone please tell me that can i use tps51980A or tps51980 insted of tps51980B??
                      Any verdict on this?
                        https://www.badcaps.net/forum/showthread.php?p=1208119
