LA-J801P schematic (Acer A315-56)
    Anyway have this one before I put money down (again) at Vinafix?
    Have a shorted cap on the +5V JW505068C regulator IC (from liquid damage) just don't know its value. The datasheet seems a bit scarce on detail from the manufacturer.
    Re: JA-801P schematic (Acer A315-56)
    Can't edit this so apologies in advance. It's a LA-J801P motherboard (doh).
    There are two caps shorted, one on pin 15, the other pin 16/17. It appears from this datasheet these are 4.7uf and 2.2uf respectively. Although titled EV5086C, it refers to JW5086C and the pinouts look identical.
    https://cdn.badcaps-static.com/pdfs/...c81d1afb15.pdf
      Re: LA-J801P schematic (Acer A315-56)
      Schematic + Boardview. Not sure if the schematic is legit,the cover page says LA-J801P, the other pages are LA-H801P and LA-H791P
      • PC-R TECH
        PC-R TECH commented
        Editing a comment
        Thanks bro
      Can you post a picture of the JW505068C
        Thanks Man
          Thank you
            Thx
              gracias Thanks!
                Thank you!
                  Thank you
                    Thanks a lot.
                      Thanks a lot
                        Many Thanks!!!!
                          Thank you very much
                            Thank you.
                              top
                                Hello!
                                Also about this motheraboard, could someone help me identifying a smd chip MESC5V02BD03_SOT23-3 which has inscrit on it L5B, to try to find an equivalent or compatible one?
                                Included i attach some pitures.
                                Thank you in advance.
                                  Hello. which software can open the schematic?
                                    OpenBoardview - https://www.badcaps.net/forum/showthread.php?t=54661
                                    Or BoardViewer - http://boardviewer.net/
                                      Originally posted by smdflea View Post
                                      schematic + boardview. Not sure if the schematic is legit,the cover page says la-j801p, the other pages are la-h801p and la-h791p
                                      thx
