Xbox 1.6 Motherboards and Polymer Capacitors
    Re: Xbox 1.6 Motherboards and Polymer Capacitors
    unless there is a jumper on the board or something, i dont know why you couldnt flash an Aladin
    i will say though, i prefer the 1.0 - 1.5 models for this reason.
      Recent Aladdins come with a different chip on them, so you can't flash them unless you have an external programmer.
      Pain in the arse because it means it's another piece of equipment that I have to buy.
      I don't usually mind buying tools, but an eeprom programmer is not something I'll ever likely use again once I've done the initial flash.
      I'll probably end up buying one though because the Aladdins can be bought for less than $10. The Open Xenium chips are starting at around 40 to 50 not including shipping.
        wellllll,
        i dont know how your flashing them, but there are several tools
        i used to install Linux, and then from linux i ran a flasher called "raincoat" or something like that.
        it recognised a hell of a lot of chips and could be updated because the chip details were in a text file i think.
          wellllll,
          I've never had to flash anything with an external programmer, so I don't have a clue about what tools and software I need.
          Any tips on the best programmer to use?
            i'm talking about in the xbox - use xbox-linux
            https://github.com/not404/raincoat
            do you know the chip partnumber?
            https://github.com/not404/raincoat/b...c/flashtypes.h
              I think the new Aladdins contain this chip:
              SST49LF002A
              which, supposedly, can't be flashed without an external programmer.
              I think I read it on this thread:
              https://www.reddit.com/r/originalxbo...less_you_have/
              SST49LF002A does appear in the raincoat file. So does this mean that these chips can be flashed while in the Xbox?
                yes, if the id is in the file it can flash it
                  Interesting! I'm going to have to do some reading.
                    Hello all,
                    I've been using an "Xgecu TL866II programmer" for ST M29F080A-90N1 (TSOP40), ST M29F002BT-70NI (TSOP32) and Atmel AT24C02N-27SU (EEPROM) for the Original Xbox. I've also been using it for Atmel ATtiny45-20SU (SOIC8), PIC12C508 (SOIC8), ST SST49LF002A and Cypress S29AL016J70TFI010 (TSOP48) for a variety of modchips. There are newer models "Xgecu T48 & T56" but cost a bit more. There's a list of supported IC's on their website. There are TSOP flashing tools/apps available for the OGXbox, I would highly recommend the one by "Rocky5", this method can only be done on motherboard versions v1.0 to 1.5 and will require 2x 0603 pads to be bridged...
                    I hope this helps, NeMesiS
                      yes, but he has 1.6 boards
                      how reliable are your tsop adapters?
                      i have hell getting mine to work without pin errors
                      obviously they arent as good as yakamichi but they dont cost $80 either!
                        He could go down the soft-modded road...
                        But depending on he's situation that may not be possible.
                        I haven't had too much issues with my TSOP adapters,
                        I would typically do 100pcs in a single sitting...
                        @stj, After spending most of the day reading through the many
                        CPU capacitor threads, your name came up alot...
                        I'm highly involved in the xbox modding community and
                        would like to talk to you directly if you don't mind...
                        Cheers, Nem
                          sure - pm me
                            Thanks, will do...
                            Well now that I think of it, I did have pin error issues.
                            It came close to driving me crazy, turned out it was the USB cable.
                            Don't ask me why...
                              i could try a new cable, but why would it not effect dip and plcc package chips?
                              i prog and dump gals and eproms all the time and NEVER get pin errors - only with tsops.
                                Thanks as always for the replies!
                                Digikey took so long to deliver the caps (over a month) that when they finally arrived I didn't have the time to fit them.
                                I'll probably do them over Christmas when I get some time off work.
                                Will post back if I'm successful.
                                  yea, that was kind of predictable using a u.s. supplier.
                                  ali-express takes 2weeks or less with "ali saver shipping" option,
                                  RS,Farnell etc take 5days or less.
                                    Hello stj and everyone else!
                                    Finally had the time to do some work on one of the Xboxes I accumulated over the year.
                                    Replaced the CPU and PSU caps with the polymers I listed previously, and they work a treat. Also removed the clock cap and replaced it with a normal 16v 470uf electrolytic.
                                    The 20-year-old caps were actually all in decent condition. All showed correct capacitance and the esr was very low - pretty much the same as the new replacement polymers.
                                    Decided to fit an XboxHD+ as well, because the good HDMi adaptors are either out of stock or even more expensive than this board.
                                    Thanks again stj and everyone else who helped me with this. Couldn't have done it without you!
