Dyson V6 Absolute Not Starting
  • VitalComputing
    • Dec 2021
    • 29
    • Ireland
    Hi everybody,
    I bought one of these and the batteries are a disaster with them. I have a second dud battery now and I'm just about to throw the thing in the bin.
    The battery is rated 21.6V and supplies up to 16A. I connected two 12V lead acid batteries in series to test the motor - the dyson starts and then stops after two seconds. I'm not sure why, maybe it is the overvoltage protection or maybe the batteries can't supply the required current.
    I'm just wondering if I put two lead acid car batteries (which would have the required current capacity) in series for 24V, drop down to 21.6V using high current diodes (in case the 24V is too much), would it do the job? Has anybody toyed around with powering with an alternative power source? Obviously I would have to carry around the car batteries but I would just put together a Ghostbusters type carry bag, so this would not be an issue.
    • Jul 2011
    • 6033
    Re: Dyson V6 Absolute Not Starting
    If you have some 20 volt tool battery packs you could test this device I would caution you that these type of battery pack have a certain amount of current that you pull from the BMS protection board so be aware of this limitation
    3 to 5 amps is the normal range higher preforms tools range is about 5 to 8 amps
    Impact gun ,die grinder , grinder would fall in the 5 to 8 amp range
    Drill driver 1/4 impact gun regulator drill fall in the 3 to 5 amp range
    One other caution you should be aware of is that some battery packs do have have BMS protection boards they are part of the charger and the tool has a voltage/current monitor circuit
    You can sometimes tell if this is the case it will have each battery cell voltage can be measured on the connector pins if this is the case do NOT use this type of battery pack to test your device in question you will no current protection for the batteries in the pack
    The other option is to replace the defective batteries with good ones and try retesting them if you do this remember that you have to reactive the battery pack by putting it on the charger before you can test the device
    I would have to agree with you suspicion that it might over voltage detection circuit which would not surprise me in the least
    If you have two battery packs you might get lucky and have enough good batteries out two battery packs to make a good one for awhile
    Do you know what size batteries they 18650 , 21650 and so on
    I hope this helps you with this type of repair
    • VitalComputing
      • Dec 2021
      • 29
      • Ireland
      Hi Sam,
      Thanks for your reply. I have drawn up a quick electronic diagram of what I'm proposing. To be honest I expected to look up youtube and find someone who had done similar, or at least a good reason why it could not be done. But I will put the circuit up there for somebody to critique. Maybe the dyson battery module also provides regulation or preparation of the voltage before it is fed to the dyson itself.
      I'm pretty sure they use the 18650 batteries, and I have a good few spares of these in old laptop batteries. But I think the issue with the Dyson battery module is more that the electronics around the battery fail, not that the cells themselves fail. This is another option for something that I could try though.
        • Jul 2011
        • 6033
        I would add one more diode for good measure first if it works correctly with this then you could remove the extra one and see if the circuit like this situation
        You could do this but I would at least use 3 amp diodes for this test so you do short them out
        I would not continuously run it on this setup unless you use 10 amp diodes at a minimum just to be on the safe side
        One thing I would recommend that you load test the 18650 cells with a automotive type headlight and record the time that the voltage is above 3.0 but make sure that you start with a fully charged battery 4.2 maximum and group them ( your time testing above 3.0 volts) as close as possible for best results with the BMS protection board unless it has balancing protection as well most of the BMS boards do not have the balancing feature on them
        You can charge 18650 batteries with out a BMS protection board but you need to have an adjustable power supply that can control current as well as voltage to do this safely charging current should not be more than one amp current and set voltage to 4.1 volts and should be alright but do not walk away from them when charging these batteries if you do not know the history of them you need to check them out for temperature issues while charging them
        If you want to walk away from them while charging do not go over 200 milliamperes current while charging them every so often I would still check the temperature on them when the charging voltage gets close to 3.8 volts and beyond this voltage until fully charged
        They should stay at room temperature or a little bit higher than but not so warm that you can not comfortably keep your hands on them if they are higher than room temperature the warmer they are beyond this temperature I would hesitated using them for this device but this just me personally one note if use the ones warmer than room temperature I would have all the batteries cells that are basically the same temperature when charging for best results but what your results will be are anybody guess
        One final note if you have a battery testing machine that has a temperature sensor in the controller this makes testing and grouping batteries a lot easier
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8090
          What is this Dyson? A cordless vacuum? I remember a friend of mine had the same problem, but can’t remember what was the problem. Apparently there is a lot of them that have trouble at roughly a year went by.
          If it would be mine I just hook my CC CV each power supply to it and crank her up.
          • VitalComputing
            • Dec 2021
            • 29
            • Ireland
            Sorry I thought these were sold worldwide. The word Dyson here is synonmous with hoover. It is an upright hoover, though it barely hooves that much these days.
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              is the dyson fully intact when testing ?
              • VitalComputing
                • Dec 2021
                • 29
                • Ireland
                Yeah it's fully intact, aside from the battery of course. There are two terminals from the battery that I have identified as positive and negative - I have pulled out the Dyson battery and have connected the terminals from the battery. These things are very temperamental as hell though, so I certainly have not ruled out it stopping after two seconds because of some other, non battery related issue. They are notorious for stopping because of issues with the filter and things like that.
                I'm going to order a few of these to drop the voltage anyway and see what happens.
                https://ie.farnell.com/ixys-semicond...00v/dp/1080095
                • carrzkiss
                  Cyberpower cps1500avr not charging batteries
                  by carrzkiss
                  Hello, all.
                  Cyberpower Battery Backup Unit.
                  I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                  When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                  In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                  Checking the voltage, it was down to 22v.
                  I quickly removed everything...
                  06-15-2024, 02:10 PM
                • howardc64
                  Where do repair shops buy MB replacement batteries?
                  by howardc64
                  Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                  Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                  BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                  07-25-2024, 10:42 AM
                • Astonished
                  Fixing the Charge Circuit of the Batteries of the DC Motor
                  by Astonished
                  Hi friends of electronics
                  What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                  The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                  Please help me fix this circuit.
                  (the datasheet of the IC: https://pdf.datasheet.live/28...
                  01-28-2025, 06:24 AM
                • markenero3
                  HELP Dell Precision 3480 Bios Password with absolute enabled
                  by markenero3
                  Good Day Everyone please help! I have Dell precision 3480 13th gen with Bios password and absolute enable. I already tried 8FC8 Patcher it works but the absolute still cannot be disabled
                  Here is my Orig bios file with Bios password and Absolute Enabled
                  Board: IDB40 LA-M402P
                  Service Tag : HFZW724
                  Thank you So much in advance....
                  02-20-2025, 11:23 AM
                • davidebaldini
                  UPS ruins batteries every three months
                  by davidebaldini
                  Problem description:
                  My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
                  UPS model:
                  The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
                  10-02-2019, 06:19 AM
