how do you resolve problems with ebay (and other shop) scammers!?
  • myth77
    • Feb 2017
    • 380
    • Croatia
    When i need to replace cpu or gpu or pch ...i mostly order reballed chip from china, but lately there are more broken ones then working.
    So lately i tried with ebay "not working motherboards". I ordered a few broken motherboards from ebay but i have found out that there are many scammers on ebay. The most of them are selling already destroyed motherboards with pictures in low resolution, some of them are being scammed and just scam forwarding...
    First board i ordered last month was ok. Cpu was dead but i could use gpu and pch. The second arrived 2 weeks ago...and it was shorted everywhere...traces of soldering all over the board, mosfets, resistors, caps missing, gpu clearly cooked in bakery and so on. The photograph seller posted was in very low resolution but on first he seemed ok because the other items he was selling were shoes...I ask him on private what is it with the board? he told me that it was dead and he just bought new one and replaced that old. Now i confronted him... and he is telling lies like "i replaced the motherboard" in the repair shop and maybe they were trying to fix it and so on... and in the end he told me ..:"on auction it was clearly stated that motherboard is not working"
    My question is (because i dont have expirience with ebay) can i open dispute? i mean he did wrote that item is defective but never "missing componens" "tried to repair" and so on...Or i just should forget about it and accept i was scammed?
    And if its so do you have any tip in the future to insure that these thing will never happen again?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: how do you resolve problems with ebay (and other shop) scammers!?
    You could try to make a claim but it was sold as faulty, however a polite message to ebay will only take a few minutes to craft.
    I'd accept the loss and only buy from sellers with better photos that have nothing to hide.
    Double checking with sellers by message before purchasing.
      • Jul 2011
      • 6031
      Do not go by that it does not work because I have been burned a couple of times thinking that it just a little problem but turns out that the device was totally dead and going to cost to much to repair so I now only buy items that do not work either because I want the enclosure to repair something that I have or I have a damaged board and taking my chances that the one I buying is not in worse shape than the one that I have already
      eBay will not help you in this situation because if it clearly state that is for parts and does not work correctly and is as is you are out of luck so buyer beware
      I still buy not working for parts only I completely understand that I have no recourse when buying something like this so I make sure that I get it as cheap as possible and willing to take the risk
      What I have done in the past is ask the seller for better pictures if seller does not respond or put some some what better pictures but you still can not see what you need to see then just do not buy it because more than likely they do not want you to see how bad the device is and I personally would not buy from a seller if they are not completely transparent with what they are selling but this is just me
      I have in the past ask a seller if this is a stock picture or is it the actual item that is for sale because this can bit you in the a** as well so be careful with this as well
      One clue is if says for recycling purposes this could be a real give away that it is probably been stripped already
      Tool battery packs that I have bought in the past on eBay that I was trying fix battery packs with bad BMS protection boards sometimes the issue was just some bad cells but the BMS protection board still working correctly this was a win but some time it was that the BMS protection board was so bad but the batteries were still good but this is rare for this type of failure see below
      One other type of failure that sometimes can be repaired is if the mosfets failure but this if-e and sometimes a waste of time but it sometimes worthwhile to give it a try
      I have repaired tool battery packs in the past from not working battery packs but I also have had some that had the same exact issue with the battery packs that I was trying to repair so it is if-e
      Another clue is if they say that they do not know what wrong with it or they do not have a way to test it this might mean that it could be a scam or they really do not have a way to test it and it really depends on how the seller respond to you to weather or not to trust what they are telling you is real or not
      Here is an example of what to stay away from I need to repair some Milwaukee M18 battery packs but will stay away from this seller
      This by itself is not necessary a red flag until you see the part that I have in red then it becomes a red flag for me
      https://www.ebay.com/itm/39410881760...3ABFBM2Ja92eBg
      Because of this description that is in red because these might be messed with already not worth the risk that is just me unless I offer something like $20.00 for the 10 and not what the seller is asking for
      “ For parts only and repair only. These batteries are defective, they have been tested and did not turn on or charge. These batteries are heavily used, and may be missing factory screws.”
      The reason to stay away from this is because they are known that they have bad batteries because they state that they have been heavily used this is another red flag but not on it own but everything else that is in the description
      Now I am not saying that this seller is not transparent but might not be saying everything either so this is also a red flag for me as well
      Now if I want to be quite I would ask the seller what was looked at if it is missing the factory screws but probably would not get a response or some type vague response
      I hope this helps you in the future
      • Benass
        • Oct 2020
        • 73
        • Uk
        Let me explain to you how EBAY works.
        If you bought an item and you know u been scammed Do the following.
        Open a dispute on your purchase with ITEM NOT AS DESCRIBED
        Send seller short message Not as described. And wait.
        The magic is Ebay using AUTOMATED system for all sales below 500£ and you are guaranteed to win. If seller ignores you, u get automatic refund. Otherwise seller issues u a return print label.
        Do not engage with seller as you might say something silly and it can be used against you in appeal process.
        Simpe Not as Described. The less u say the Better it is for you.
        If you a seller this is what will happen and there is fak all u can do.
        • clearchris
          • Dec 2013
          • 687
          I'll generally not buy something as "not working" but I don't have an issue with "untested." I also won't buy something on ebay that's a popular item that generally requires repairs, i.e. game consoles, fancy video cards, etc. Most of my ebay purchases tend to be obscure items (wierd commercial equipment), and cheap enough that if I have to make major repairs, I'm ok with it.
          If there's a question, I'll look through the buyer's other for sale items and see if there are any signs of trickery. Also, anything less than 98% feedback is pretty much a no-go for me.
            • Jul 2011
            • 6031
            I with you on this and most of the time I go with this but there are times that I will if the price is right and I look closely at the reviews of other that have dealt with this seller and do not see any red flags I might take a chance buying something from the seller
            The lowest feedback rating that I will consider is 95% but it depends on what the negative and neutral reveals about this seller and how they treated there customers
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              If nothing else if he reports the problem, then if Ebay takes some responsibility, they may stop the deceptive practices like they used to when I was willing to buy from them.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8694
                When buying defective devices for parts scavenging, I'd need to make sure the parts you want to salvage is clear in photos, and the seller can demonstrate those parts are working, before making a bid. If they can't for either, the value of their item drops significantly to me.
                I ended up buying an oscilloscope "for parts or repair" and was lucky to be able to repair it mostly. Still not perfect as I don't have the tools to fully calibrate it , but at least it was exactly as I expected it to be...
                • myth77
                  • Feb 2017
                  • 380
                  • Croatia
                  Thank you all for the tips
                  • DXseekerMO
                    Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                    by DXseekerMO
                    Hello everyone!
                    Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                    I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                    Yes
                    0%
                    1
                    All backlight strips are the same quality
                    0%
                    1
                    No
                    0%
                    0
                    12-16-2021, 03:58 PM
                  • odonono
                    Louis Rossman style repair shop for regular laptops?
                    by odonono
                    I made a post over on reddit about how my windows laptop only works when plugged in now, because I dropped a screw driver on the connector pins where the laptop battery plugs into, causing sparks. I put a brand new battery in but still the same result, so something on the board obviously got fried (however, there's no visible burn marks, so no clue what was affected). I honestly wouldn't care, but my laptop is power throttling even with the internal battery unplugged (turns out this is a common problem on laptops with poor batteries or missing batteries). The GPU won't go above 40W when the TDP...
                    03-06-2024, 07:31 PM
                    LED Solar Flood Light Dusk to Dawn Security Wall Street Yard Outdoor Lamp modifications are in order
                    by sam_sam_sam
                    I bought one about a month ago from an eBay seller who now is out of stock however I found another eBay seller that has the same version of this device so I think about buying a few more of over a period of time
                    Awhile back I bought some A123 brand 18650 battery cells that are 3.2 volt battery cells that I am going to use in this device for more running time in a florescent bulb fixture that I gutting out the tube sockets and turn it into a solar powered LED lighting fixture instead
                    Pictures will come later when I have the lighting fixture gutted and have the battery...
                    08-11-2024, 11:10 AM
                  • MrCommunistGen
                    Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                    by MrCommunistGen
                    My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                    I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                    07-12-2021, 05:11 PM
                    Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                    by sam_sam_sam
                    I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                    https://www.ebay.com/itm/116497313155?var=416785404161
                    Here are some of the description from the eBay seller
                    The main parameters:
                    1. Product name: High-power non-isolated DC boost module power supply.
                    2. Product model: 100A2000W.
                    3. Input voltage: DC12V-60V.
                    4. Input current: 100A (maximum)....
                    05-18-2025, 09:45 AM
