Garage light only lights up when you hit it. Make your guess as to the cause!
  • SluggerB
    • Aug 2020
    • 747
    • US
    The flood light over my garage was hanging out of the house due to the previous moron not knowing how to anchor it correctly. So I fixed that today
    I then go to turn the light on tonight, and it doesn't stay on. If I tap it with a piece of wood, the lights come on for a sec them dim. Repeated tapping will cause it to eventually start working, until the switch is flipped, then it's a 50/50 shot it will work again or need to be tapped to start
    So tomm begins the diagnosis. What do you think it is? Vote now!
    A: A loose connection in a wire nut. I tugged on them to make sure they were snug, but the amount of wire exposed from the insulation was kinda short. Maybe screwing the wire nut on pushed it down and make a flaky connection?
    B: Damage to the supply line. I had to mount the box in there by building out a little frame to hold it and tapping it in place with a hammer. Maybe I pinched a wire when installing the box?
    C: Bad fixture. The thing is probably mid 70's and could have some loose internal connection
    Vote away, I will be taking it apart tomm and will report back with what I find
  • SluggerB
    • Aug 2020
    • 747
    • US
    Re: Garage light only lights up when you hit it. Make your guess as to the cause!
    It was the fixture, specifically the motion/light sensor. I opened it up and got to the board and water must have gotten in there at some point, the sensor was all rusty. I tried to clean it and reflow as much as I could, reassembled the light, but it still required tapping on the sensor to get the lights to come on, and shortly after it broke completely.
    So I rewired the fixture to bypass the sensor and now it operates as a normal switched light (which I actually prefer anyway)
      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
      by sam_sam_sam
      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
      I am comparing them to a brand new one that I installed
      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
      I going to let it run for several days before I remount back on the wall next to the...
      09-05-2024, 06:48 PM
      LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
      This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-07-2024, 03:40 AM
      LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
      This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-06-2024, 09:10 PM
      09-06-2024, 08:40 PM
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
