Hello all,
My first post here. I'm just a hobbyist with a basic understanding of electronics.
Been reading a lot about this Dell 2408WFP monitor in various posts on this site and they've been useful.
I have the same issue with this display that others have experienced in that the display does not turn on after it has been disconnected from power.
This happened again a few days ago and this time I could not get it back to life, even after repeatedly disconnecting / connecting the power.
So I opened it up to have a look, especially bad caps. Did not find any though, although still replaced the startup Jamicon caps with Rubycon. No fix.
Then when checking VCC on the 1203P60 PWM chip I made the same finger slip-up with the probes that others have and shorted pins 3 & 4. BANG!
Several blown components amongst one is inductor L611. There are no markings of any kind on this component, not on the PCB or on the schematic (which I've included, with a mark for the location of L611).
Also pictures included of the PCB and the inductor itself.
There are three other inductors on the PCB of identical dimensions. I took L613 off the board to test it, but my component tester sees at as a resistor with a value of about 1 Ohm. The same goes for the (faulty?) L611 which reads a similar resistance.
So I don't know what the value in Henry is.
Can someone inform what kind of inductor this is and its likely value?
Just so I know what to order as a replacement.
Many thanks!
Many thanks!
