Re: A2159 - 820-01598 - Stuck at 5V and am a beginner looking to learn
Yes. With these 2 resistors OFF the logic board, power up again.
Measure the voltage to ground at C6912, pin #1.
What is the voltage? If it is ~3v3, the regulator @ U6903 is working fine and does not need to be replaced.
Next, remove all power -> dial up your power supply to 1 volt (NOT higher for safety - in case the power rail is shorting to the CPU rail through a leaky mosfet) and 2A-5A current.
With no power to the logic board but using only this external power supply, attach the RED power supply probe onto R6934 or R6935, pin #1 (either one is ok). BLACK power supply probe to ground (shield is ok).
The power supply current consumption should spike due to the ultra low resistance on this rail.
Who is heating up using this process? You can pour IPA onto the board / area you suspect is causing this short. The IPA will mist up and evaporate quickly from the heat. With some luck, it will be a defective capacitor which is quite common. The longer you keep the probes attached, the hotter the shorted component will get. Hope it is not the CPU (do monitor the CPU without a heatsink). Often the caps are tantalum style and they split / crack open under this event. Tantalum caps are just crap and they short circuit when they die over time. Once you home in on the shorted part, remove that part off the board with flux and low air pressure, so the parts do not go flying (without a license).
Then allow the board to cool down and measure the resistance to ground again for the same short condition.
Post your updates and measurements.
it suggests that the short is further downstream?
