Sony XBR-65X900E 4 Blink Code
    Re: Sony XBR-65X900E 4 Blink Code
      I looked at a similar board over and I see several places that are labeled fuses but I'll be damned if I can tell where they are, I know some will have a label but just not be included in a particular design.
        I think I'll try a new main board and see if that gets this working again. Not sure what issues it might have at this point.
          ok, if you are sure you are getting a new mainboard, something you can try if that there is a cap and not a fuse, is just remove it with a soldering iron and try the tv, I have seen this work, that is removing a shorted cap and tv working with it removed.
            if you find a place with decent prices send me a message, still need one for my 900c.
              Going to see if I can find one in a known working condition on ebay.
                The fuses are in the photo, the motherboard has nothing to do with error 4 associated with the LCD Panel ...
                  The circled fuses are not blown.
                  So the above chart is showing 4 red flashes means the panel itself is the issue?
                    This is everything related to the panel, backlight (leds), led driver, power led driver...
                    There is a problem with the panel or with the T-con, then the error would be "5".
                      I think it’s backlight related. Unplug the blue tabbed cable from the main board and plug the tv in. It will do a backlight test and if it the leds are good the leds will stay lit
                        Note you might have to unplug the lvds cables going to the tcon also.
                        I'm not sure as I already had the screen out and those cables unhooked when I discovered the led test cycle.
                          It's going through a color pattern, checkerboard pattern. No signs of it turning off. It's playing ambient music as well.
                            I had 4 blinks plus many shorted caps on mainboard, have not decided on replacing mainboard but I think thats the issue.
                              Originally posted by nomoresonys View Post
                              I had 4 blinks plus many shorted caps on mainboard.
                              It could not be a short circuit, but a very low resistance on this bus (processor core power), just like on this 4 ohm board.
                                Well, you wanted to order a motherboard (and that would be the same mistake).
                                  I found a set of all boards from a supposed cracked tv.
                                  Might get that and change out all the boards.
                                    Well whats the answer then, storyteller just said if the backlights stay on they are ok and they stayed on.
                                      The answer is this - the protection of the led backlight is turned off and the processor thinks that everything is in order with the backlight.
                                        ok, just to satisfy curiosity can you test that cap on the new mainboard when you get it, to see if it reads the same.
                                          ok, I get it, thanks for explaining, so it could still be a backlight issue.
