Re: Samsung UN55HU8550F - No picture, No sound
I went in and started looking at the power supply again. Measured voltgaes and tbey were all in spec and steady. I measured them with the mainboard removed. When i unplugged the mains and proceeded to plug the harness from the mainbkard i heard the clicking of the relay again where tbere was no clicking while i was testing it in isolation. Something has gots to be up with tbis mainboard.
It also occured to me that, while the backlights i installed seem to be much better than the ones i had in there before, i should have tested them with a backlight tester before install. They came from a donor aet with a cracked dispaly. This was confirmed by a photo of tbe actual TV powered on, displaying and image witb a cracked screen. Even though it worked in the donor TV it may have been on the edge of functionality and could be causing the same error as my old one. Just speculation but i will definitely test them when my BL tester arrives.
I also took a few minutes to apply hot air to the two BGAs there in case some loose solder joints maybe the cause of the issue but no joy.
